ae86 non pw/s arms are 135mm while pw/s arms are 115mm ball joint to tie rod hole.
the shorter the arm, the heavier* the steering becomes but more responsive.
* the steering wont be that heavy with standard pw/s arms, but when you get knuckles that are about 85mm, without powersteering your steering will be pretty heavy, especially at low speeds.
