well if its inbet where do the lines go? hehe
just put it in front like everyone else ddoes OR you can be a boso dude with it on the front bar yeaaaaaaaaaaaaaa
Car -ae71
motor -sr20
use -skids
problem - what i was questioning is positioning my oil cooler in between my inter-cooler and radiator, the issue im seeing is the air is just gona get hotter as it passes through the inter-cooler and oil-cooler and then finaly reach the radiator,
so what i want to know is your opinion on the position and also whats the best way to mount an oil cooler, with the inlet and outlet on its side or to the top or bottom
theres a couple of pics on how i was gona do it but unsure
the oil cooler will recieve turbulant air flow + also restricted airflow if mounted their, side ways up ways cross ways, doesnt matter, as long as the air can pass freely through the core it will do its job well.
and just imagine if you had to tighten one of those fittings
put it on the side somewhere
roof mount.
check out prewers ae71 build thread. I did my oil cooler that way a year ago and it works sweet!!
