Results 1 to 6 of 6
Thread: dose the ra65 brakes fit any thing?
    Senior Member 70wagon's Avatar
    Jarrad
    Barossa
    Default dose the ra65 brakes fit any thing?
    hey all just wondering if the ra65 vented brakes fit any struts that fit a ke70???
    Veteran slydar's Avatar
    Dimitri
    the disc (and hub) will go on an xt130 strut.
    but the caliper wont. theres another toyota caliper that will, but you still need to do some machining.
    andrew
    can you get the struts/steering arm the brakes came off ? you can use them with your top mounts and put them in your 70 (if there the same as ae86)
    Ra60 struts give you some neg camber but some other struts that fit can give you pos camber but i cant remember the model.
  • #4
    Mt Macedon
    ^^ Nope, RA60 struts (along with all other A6 celicas) give positive camber in an AE86 or E7. Can be negated by bending the struts or Sigma arms. I've heard of some rare Cressidas or Crestas which might have a suitable strut, but haven't seen the myself.
    Answering the original question, there is no easy way to fit those brakes. Slydar's suggestion is the best IMHO. Search Toymods for "$250 vented brake upgrade" or somethign similar. All spelt out there.
  • #5
    andrew
    ah ok, weird we fitted some struts (thought to of been ra60) on an 86 and it had 1.something neg camber, it must of had diff control arms.
  • #6
    Mt Macedon
    Weird, RA60 definitely give positive camber, but also they don't bolt up to AE86 steering arms (slightly different bolt spacing). I'm guessing you had struts from something else. Plus I don't know of any strut swaps to give -ve camber in an AE86. So I'd suspect the control arms had been changed/modded.
  • Similar Threads
    1. *NEW* MX73 BC RACING COILOVERS SET(also fit ra65, rt142 etc)
      By sumfancyname in forum Car Parts For Sale
      Last Post: 29th October 2012, 12:53 PM
    2. [SA] RA65 Struts w/Brakes. Great entry level upgrade
      By Javal in forum Car Parts For Sale
      Last Post: 5th June 2011, 02:41 PM
    3. Sprinter shocks to fit ra65 'rear'
      By Pandara65 in forum Technical - Questions
      Last Post: 19th February 2011, 11:05 AM
    4. Radiator for a ra65 i believe cressy ones fit nsw central coast
      By bigdaddykane in forum Cars or Parts Wanted
      Last Post: 14th April 2010, 03:53 PM
    5. RA65 springs - fit what struts?
      By touge_rps13 in forum Technical - Questions
      Last Post: 25th May 2009, 10:32 PM
