Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 11 to 20 of 47
Thread: beams 3sge conversion?
  1. #11
    Anthony
    please dont
  2. #12
    Glenn
    North Ringwood
    the rods and the high comp wont like any thing more than 6 psi
  3. #13
    Veteran biggo's Avatar
    Nick
    Noosa
    sif, my gen1 love the 14.7 psi the world gives it.
    I lol everytime
  4. #14
    Nov 2009
    Flaxton
    Lol thanks for all your input. Ive been looking for performance parts, and not that cheap compared to sr20, there is a wide range of parts for sr's on ebay, whole engines, forged bottem end, injecters etc, and OS Giken input shaft
  5. #15
    Nick
    Noosa
    yair but SR20's break thats why you need forged this and upmarket injectors and somebignamejapbrand shit.
    Buy a toyota and enjoy life under the radar.
  6. #16
    Nov 2009
    Flaxton
    yeah i suppose toyota's go with toyota motors lol
  7. #17
    Veteran shift_rook's Avatar
    SE Burbs
    if you want provenm big power, go sr, if you want something top make peoples jaw drop, but have to spend a fuck load more to do it, go turbo beams
  8. #18
    User fantapants's Avatar
    Pat
    or just last gen 3sgte... talk to bealy?
    good numbers out of the 3sgte.... supposedly the head and dual vvti will help in a turbo setup, but the factory magik of a toyota would be hard to replace
    06/07/2011
  9. #19
    Nov 2009
    Flaxton
    no i dont have a lot money but if i go with beams, they have 154kw which should be enough to learn to drift and have a bit of fun. Hopefully acquiring the parts slowly as i get the money, thats if the motor doesnt go pop
  10. #20
    Senior Member Prime86's Avatar
    Sep 2009
    Brad
    Perth hills
    Heya Tbo92
    First of all awsome choice of engine to fit to an 86. These engines are one of the tuffest N/A motors around and can produce some serious power for a 2 litre engine. I was toying with the idea myself but because of the High comp setup its best to do work to the motor before bolting a turbo on the side or you will have problems when pumping boost into it, any more than about 4psi. They run 11.5.1 compression ratio and this is way to high for a turbo engine. I would put a set of pistons that Toda make and drop it to like 9.5.1 and a set of rods to make it reliabe and be able to put 20+ psi in it with big power gains. Have a look at Beu Yates trd AE86 on youtube which is fitted with a Beams 3sge turbo engine. Hypertune make an awsome intake manifold for the beams turbo engine but you will pay for it. Anyways mate good luck with it and hope it goes well for ya.
  1. 3SGE Beams
    By Jacobxxx in forum Ebay Items - My Stuff
    Last Post: 29th October 2012, 12:03 PM
  2. 3sge beams conversion question, factory ecu
    By sundee in forum Technical - Questions
    Last Post: 26th May 2012, 02:20 AM
  3. 3sge Beams Coilpack
    By HiroshiFumi in forum Cars or Parts Wanted
    Last Post: 14th January 2012, 06:33 PM
  4. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  5. Beams 3SGE -some advice please
    By kestrel in forum General Topics (No Technical Questions)
    Last Post: 28th September 2009, 10:06 AM
