Results 1 to 10 of 16
Thread: Couple of suspension q's
    Senior Member Moebius's Avatar
    Christian
    Default Couple of suspension q's
    I'm just in the process of putting ae86 struts with ajps springs into my ae71, and I've got a few questions.
    Brakes lines - what can I use? The 86 struts came with chopped lines, so I can't use them. Can I use the 71 lines on the 86 brakes? I've had a look and it seems feasible, but they have a slightly different head and brakes are pretty important so I want to make sure.
    Refurbishing the brakes? What should I check to make sure the brakes are going to work as expected? I've taken them apart and the piston still moves, if a bit stiffly. Should I put grease in there somewhere?
    Non captive spring problem? I've heard of people using wire or even cable ties to keep the springs in place, but is this the preferred option? Any pics of how it's done?
    Veteran slydar's Avatar
    Dimitri
    hoses should be fine, post some pics would help. there arent too many different systems, your car should have inverted double flare 45* taper both ends. otherwise new ones from auto parts place (non genuine) should be $40 or less each (ae86 fitment)
    caliper should be fine. reserve maintenance for when you rebuild them. reco' kit is cheap and its pretty a pretty easy job.
    springs. dont worry about. its on a strut. cant go anywhere really. only a prob really at the rear where it can call out. if youre worried, all youre trying to do is keep them in place, so if the strut uncompressed to the point of the spring being loose, it wont come a drift and seat incorrectly. the way the spring seats are designed, this is rarely an issue unless your springs are very very short and you have very long travel shocks.
    Christian
    Thanks Slydar. Regarding the brake lines, one seems to flare inwards and the other outwards, pic attached.
    I get what you mean about it being on the strut, I was just worried about it compressing on an angle or something and damaging the perch. Just being paranoid I guess. Although I will have a problem in the rear as I have lower springs for there too.
    wats shocks u runnin in the rear...for cheap but effective substitute id suggest vl/vb shocks which are quite stiff but with some bounce, or even better some sierra shocks which is what i ran with facon springs and were a good combination and will not have any spring captive problems
    Christian
    I've already got some kyb shocks to go with ajps springs.
    Yet another question, concerning this bar. I'm not sure what it's called but it goes from the LCA to the chassis rail. You may not be able to see it but that nut is welded on. Is it supposed to be like that?
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    You'll find the AE71 brake lines aren't long enough, just have some new ones made up.
    try chissel or work it off.. it shouldnt be welded.. i pulled mine apart the other day and it just seems to be sum old skool loctite.
    Elite rthy's Avatar
    Leo
    Tulla
    u can buy ae86 brake lines for $30 per side
    brake rebuild kits can be bought from toyota, i think they where $50-70 the pair?
    Senior Member Stain's Avatar
    Derek
    Far North
    Quote Originally Posted by Moebius View Post
    It's called a tension/castor rod and its there to adjust the amount of castor angle your front wheels have. So that nut SHOULDNT be welded. It needs to be free to give you a propper adjustment.
    This is how it goes on: http://www.battleversion.com/img/AE8...s/DSC01346.JPG
    Moderator
    Jay
    Quote Originally Posted by rthy View Post
    where should i get these from. repco wants $75 per side
  1. couple of skid vids
    By Simon-KE70 in forum Offtopic Discussions
    Last Post: 3rd May 2009, 11:51 AM
  2. need a couple of things for the rolla
    By thatAE71 in forum Cars or Parts Wanted
    Last Post: 26th March 2009, 12:12 AM
  3. Just a couple questions...
    By McDrlft in forum Technical - Questions
    Last Post: 2nd August 2008, 12:42 PM
  4. Couple of these things ??
    By Matt_Sideways in forum General Topics (No Technical Questions)
    Last Post: 13th July 2006, 07:18 PM
