Results 1 to 10 of 15
Thread: Should pulse be used for stick welding?
    Senior Member Vezza's Avatar
    Vesley
    Geelong
    Default Should pulse be used for stick welding?
    I know the pulse function on a TIG/Stick welder is generally used for the TIG. But would stick welding also benifit from using the pulse function.
    From what I can figure out, it probably would, as the function of the pulse is to momentarily pulse a much higher current than the base welding current. Which helps with penetration and fusion, without burning through the metal.
    Would this be correct?
    Member SSD20V's Avatar
    Telly
    Inner West
    You can only use pulse in tig mode,dont think it operates under stick mode.You mainly use pilse on Aluminium tig.
    Vesley
    Geelong
    The pulse function works on either tig or stick with my welder.
    Andrew
    No need to pulse on stick, I've never tried pulse on stick welds but i'd imagine you'd get issues with sticking electrodes and funky looking weld beads.
    I use the pulse mode only on very thin aluminium jobs.
    Telly
    Inner West
    Has your welder got a button to switch between stick and tig ?
    Vesley
    Geelong
    Yep, and even in stick mode if you have the pulse on, you can hear the machine pulsing.
    Senior Member KE70's Avatar
    Alek
    Lalor
    Get two bits of steel, do half with normal a weld and half with pulse.....see which is better.......problem solved, lol
    Vesley
    Geelong
    Lol the problem with that is, to actually see the benifits of a good weld it needs to be x-rayed, for penetration and fusion. Guess I could cut em up....
    Craig
    Northern Beaches
    do both welds, then put them in a press and break them, see which one breaks better. thats how they taught us at tafe.
    User fantapants's Avatar
    Pat
    shouldnt "practice" welds be done and broken at the start of every days work or change of job? just to check your setting s etc etc?
    so weld two scraps of the current metals together at what you think is the right setting then smash with a hammer... should bend and break befor the weld fails... or so i got taught?
    06/07/2011
  1. Weak injector pulse
    By Matt in forum Technical - Questions
    Last Post: 18th December 2011, 11:54 PM
  2. No injector pulse on 4agze
    By Sprintn in forum Technical - Questions
    Last Post: 19th September 2011, 06:09 PM
  3. what welding rods to use when welding a diff???
    By macca1590 in forum Technical - Questions
    Last Post: 14th March 2011, 10:36 PM
  4. no injector pulse 4age
    By cozmic in forum Technical - Questions
    Last Post: 7th February 2010, 10:56 AM
  5. injector pulse
    By johnO2 in forum Technical - Questions
    Last Post: 30th July 2008, 12:28 AM
