Results 1 to 10 of 19
Thread: Good size MC for RX7 brakes?
    Jonathan
    Default Good size MC for RX7 brakes?
    I got the AJPS brake adapters and assembled the kit with RX7 series 4/5 brakes etc... But I put it all on a friends car. I used my calculator and thought the stock MC would be the correct size, 13/16". But after a few days at the track my friend still says the brake pedal is way too soft.
    From experience, what size master cylinder do we think is right for the Mazda 4-spot brakes? Assuming a totaly standard car has normal pedal firmness and travel.
    And maybe running the standard MC with no booster is an option. (Is it legal for roadworthy inspections?)
    Sutherland
    I had R32 4 pots with a disc rear end and had a Mitsubishi FTO master on it.
    It was a 15/16 bore and gave a good pedal.
    Mt Macedon
    When I ran FC calipers I used a 15/16" master (and otherwise totally stock braking system, including rear drums). This felt fine too me, but I'm not the pickiest driver around.
    Nissan R32 NA Master Cylinder (Non Abs)
    Skid Kid
    with booster, Starion 1inch
    without booster, stock master
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    I run the RX7 S4 calipers and use the R32 4 Door non-abs master. Definately firmer than the std AE86 item, but doesn't feel to stiff. I believe its 15/16 size, still using the std booster.
    Andrew
    Got a feeling the r32 non-abs might be 7/8ths. So just a step up from 13/16ths.
    I might be getting confused with the mirage master though...........will confirm (it's sitting in the shed).
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    i hear a mitsu pajero mc is the way to go. bolts up to the standard booster and isnt too long etc.
    havent had any experience with it myself but its what JHS said to use in the FAQ. the part number on the FAQ is for the correct pajero mc to use. may aswell buy a brand new one
    Senior Member Roo.'s Avatar
    Andrew
    Gold Coast
    yea i have the pajero master cylinder, got hilux brakes at the front and standard rear disk seems nice and firm pedal but i haven't done any hard braking yet
    Paul
    Quote Originally Posted by Matt-AE86 View Post
    +1
    I have one on my car, improved pedal feel greatly, and bolts straight up.
  1. Jdm 86 brakes (swap for RX7 brakes)
    By Shitbox in forum Cars or Parts Wanted
    Last Post: 2nd July 2012, 06:32 PM
  2. Rx7 front brakes versus rim size
    By AIROCOBRA in forum Technical - Questions
    Last Post: 24th May 2010, 11:53 PM
  3. rx7 brakes on a Sprinter
    By Blizzerd in forum General Topics (No Technical Questions)
    Last Post: 27th April 2010, 04:45 PM
  4. Bleeding brakes with a dry MC?
    By Moebius in forum Technical - Questions
    Last Post: 3rd March 2009, 06:57 PM
  5. WTB RX7 brakes
    By Johnny_08 in forum Cars or Parts Wanted
    Last Post: 20th May 2007, 02:46 AM
