Results 1 to 8 of 8
Thread: Hilux 4 Pot brake upgrade.
    Jul 2009
    Daniel
    Morisset
    Default Hilux 4 Pot brake upgrade.
    this thread is quite simple ...
    whats needed for the hilux 4 pot upgrade?
    obviously the calipers
    what disk's do you use for it, are they a fully floating disk or disk & hub assembly?
    will you need a better brake master cylinder? ( mines already upgraded but for all those who's arnt)
    who can you get the caliper brackets from or have you had some made?
    what struts are you running them on?
    what size wheels will you need to clear them. the standard hilux wheel is a 15" rim ... but can you fit 14''s?
    how many different ways can this upgrade be done
    what was your total cost doing this.
    where are good places to get the required parts?
    alright if anyone can see anything else that should be added to the list let me know other wise go nuts and let us know what you got.
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    ok
    XT130 Struts and Hubs
    Peugot 604 Discs (DBA272 or equiv.) machined down to 266mm in diameter
    Hilux/Landcruiser 4-spot Calipers (LN106)
    the calipers will bolt straight to the corona strut
    ~KEEP DRIFTING FUN~
    Veteran shift_rook's Avatar
    SE Burbs
    pretty sure it's peugot rotors with the xt130 struts, pm ae71 kid, he's running the setup, he should be able to help, hope he doesn't mind me plugging him, haha
    Veteran slide86's Avatar
    Huw
    Hills
    Reeece
    Casula
    I am running this setup with 14" rims good thing about the hilux calipers is ,you can run s15 front brake pads so u got alot of variety
    Mark
    just so everyone knows i can source the hilux/landcruiser calipers for $150. both types ( the same size piston ones and the odd sized piston sets have a look at the toymads thread for pics of them.)
    Jul 2009
    Daniel
    Morisset
    i got one yesterday for free cuz we had to replace one. but i can get them for $125ish.
    im gonna see if it will bolt onto my celica struts
    Jul 2009
    Daniel
    Morisset
    well that sums it up mainly ... good job on that find ... now comes the trial and error part for all of us. also i have the pajero master cylinder ... featured in the link ... very good and easy to do ... but you NEED a fitting from a ford laser linx for this ... in the link its the goldish part on the front of the master cylinder
  1. Replies: 5
    Last Post: 12th July 2009, 08:44 PM
  2. Hilux brake upgrade part #
    Last Post: 22nd December 2008, 01:42 PM
  3. hilux xt130 brake upgrade
    Last Post: 6th June 2008, 10:17 PM
  4. can't afford a 4-pot brake conversion?
    By 741 in forum Offtopic Discussions
    Last Post: 6th June 2008, 01:04 PM
  5. pot pot pot pot panda ae86
    By hfae86 in forum AE86 Owners Forums
    Last Post: 4th March 2008, 05:09 PM
