day 3
so jumped under the rear end to find the diff assembly suspiciously loose,
so out it came to find this
you may notice a difference in sizes for the bolt holes or maybe some missing?
the rear diff carrier was also the same and the front carrier holes where all slotted from the movement,
old bushes seem to be to blame as the ole one were rooted,
so in wnet all new superpro bushes
Rear suframe
controls arms and lower shock bushes all replaced
the car also came with some strange camber adjusting tabs/bolts so these were welded onto the subframe
also heres a pic of the fuel setup
so hopefully by tues night i should have the rearr all back together,
im getting the car ready for the tas drift series round 1 on march 6th hopefully im ready by then
atm list of things to do
Bolt in rear subframe
bleed all brakes and replace front brake pads,
clean up engine bay and mount ps resovoir properly,
change coolant to toyota red with redline water wetter and instal 82 degree thermostat
start prepping for paint, Matt black again of course
and a quick check of the tune
also need ot organise wheels and tyres, front i think are sorted going to run 15x8 -25 black sunraisers and rear will be anything i can find
more updates to come through out the week
