Results 1 to 2 of 2
Thread: 4AGE 20v Help! - won't start!
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    Default 4AGE 20v Help! - won't start!
    Car - JDM AE86
    motor - Blacktop 20v AE111
    problem - The car just keeps on kicking over but doesnt want to start. There is spark, though maybe no fuel?
    occurs/started when - Well i took the AE92 Smallport engine out of the car after i owned it for a couple months and decided to take the 20v option. The car was previously running before i decided to do the conversion.
    So basically the 20v is wired up to a Adaptronic loom and ecu, (done by ant) the engine is in, wired up with the JDM loom but i cant get it to start.(just keeps kicking over)
    Some people have suggested the FCOR but i cannot find the FCOR, maybe as the previous owner took out the bigport and went with the smallport option so maybe bypassed it somehow?
    Any help would be appreciated.
    Anthony
    1> Is everything powered up with key on? (ECU, injectors, coilpacks, COR)
    2> Is everything powered up with key in START position? (as above)
    3> can you hear the pump prime for 3 seconds when you turn the key on?
    4> Assuming the pump is audibly priming, is fuel pressure making it to the engine?
    They're the basic checks, beyond that it's best to get a laptop plugged in and check stuff like cranking RPM and sensor values from the ECU's point of view. Just PM me if you need any other help.
  1. 4age in ADM 86 won't start. Wiring?
    By genkin in forum Technical - Questions
    Last Post: 31st December 2012, 09:27 AM
  2. 4age won't start
    By Brokenships in forum Technical - Questions
    Last Post: 1st June 2012, 11:10 PM
  3. 16v 4AGE dies warm then won't start again
    Last Post: 3rd May 2012, 10:06 AM
  4. E7 4AGE Won't Idle, Not Hunting Or Cold Start
    By KurtHS in forum Technical - Questions
    Last Post: 3rd November 2011, 06:26 PM
  5. 4AGTE won't start
    By AE86slut in forum Technical - Questions
    Last Post: 18th August 2006, 05:03 PM
