Howdy guys
Ive just got a shipment in of slim line ball joints, tie rod ends and rack ends suit ae86/ke70 and most other mac strut rwd toyota (ke30-70, xe7x-ae86, xa2x, xa4x, xa6x and rt142, and many more - ask for full list) from 74-87.
The ball joints are BJ145 part number. Tie rod ends are TE489L (will not fit ae86 unless you have dual adjustable tie rod tubes (ra40/ke30, ajps, noby booth etc) which are a necessary upgrade with longer lower arms. Rack ends are RE862. Theyre instantly recognisable by the AJPS signature black finish.
The joints are fully sealed (no grease nipples), filled with molykote2 super high performance grease from the factory. The boot is also sealed to the housing and on the ball joints is further secured with spring wire. They both have micro finished hardened balls and forged casings further increasing smoothness and strength. The boots are much thicker than others ive tried and since they dont need filling the chance of the boot splitting is also nil. Theyre also UV treated so the rubber doesnt perish.
Why buy these ball joints when i can get some from my local autostore (if they have stock)?
My search for the highest quality steering parts started when I was approached by a rally ae86er saying his ball joints only lasts 2 meets if that! Around the same time I was approached by another ae86er who wanted 13inch wheels, low ride height and a 40mm rca. He said he couldnt achieve this as the ball joint scraped on his rim.
A grabbed a ball joint from the local auto parts store for comparison - it was a wasp brand BJ145 - it was 113mm from top of pin to bottom of grease nipple. My joint was 84mm, this distance was all in the bottom section where they were fouling on rims. Im ultra confident in the products and will be offering a replacement warranty if youre not completely satisfied.
Tie rod end from shop was 80 and my tie rod end was 71mm.
These suit restorers who want to refresh their car and have it last for many years to come. Rally and drifters whose cars get harsh use. Cars that need to go over the pits. Car that want to run a large rca with a small wheel.
To get these Ive had to buy quantities of 100 of each which brought the price down quite a bit.
And can offer the ball joints for $35ea
and the tie rod ends for
$25ea
Rack ends for $28
Please not these will be used excluisively in Kelway LCA and AJPS tie rod end kits.
For this week only ill be offering FREE austrlalia wide shipping.
For those that are interested, theyre manufactured in Taiwan for AJPS to ISO9002 standards. The company is very well established in the manufacture of quality steering parts.
FITMENT GUIDE - THESE BALL JOINTS SUIT THESE CARS or CARS WITH THE LOWER CONTROL ARMS FROM THESE CARS
FULL FITMENT LIST
(KE2#TE2#) LOW R/L 70-74
STARLET KP4#, KP5# 73-78
43308-12030 SB-2162 CAMRY/VISTA RA4#,RA5#,TA4#,TA5# LOW R/L 80-82
43308-19035 RT13#,TT13# 78-82
CORONA AT40.ST140,TT142,CT140.exc/STD 82-87
KT14TV,TT147V,CT147V 82-87
YT140,CT140.,STD 82-
TA 1 #,TA2#,TA3#,TA4#,TA5#,RA 1 #,RA2#,
CARINA/CELICA RA3#,RA4#,RA5#.MA4#,MA5#.TA6#,AA63,
SA63.RA63,CA60,SA60 81-86
AA60,SA60G 81-
KA76A,CA67V,TA67V 81-
KE3#,KE4#,KE5#,KE6#JE3#,TE4#
COROWSPRINTER TE5#,TE6# 74-79
KE6#,AE7#,CE7#,TE7# 79-87
TE71,AE85.AE86 81-87
Will be offering bulk discounts on 8 units or more.
