you can, and I can supply
do you also put a washer in the drivers side for a little bit extra?
Do you have to run different lcas to fit this on a AE71 rack? also will this help reduce the amount of turns in the steering wheel to achieve full lock also making steering more responsive? cheers
best to run xt130 lca as then you dont need to trim your tie rods to run toe out
it wont reduce the amount of turns
quick rack and shorter knuckles do that
pm me
so this will be OK with standard AE86 lower control arm and standard AE86 tie rod with AE86 power steering knuckles on a AE86 manual rack?
if yes to all, can i place an order for x1
can deposit money tomorrow (Thursday) ASAP!!
PM me answer and bank details please, lol
dose
no worries you have pm
Apparently the AE86 power steering racks will blow seals if you install rack spacers, there are a few guys over in Ireland that found this out, but at the same time i dunno how much they spaced it out by. Has any one tried theses on a power steering rack with much success?
Also the 6mm spacer for the drivers side, has that got tabs and recesses to use the fold over retainer washer?
no, most people use light loc tite
i can look into it
cam they probably spaced the drivers side too much and ground the teeth off the column
Do you guys sell control arms to suit the spacers for a KE70 rack? cheers
