you know I'm about to put my 4age with quad throttle body setup up for sale. If your interested I could sell you that!
forgot u had those gay struts
ive got a pulley set id sell if u really feel the need to go a solid pulley rather than stock harmonic balancer...
MY AE86 BUILD
may look into it dude.... kinda have a fresh motor sitting waiting for me though
haha yeah gay struts for sure man..... other wise i would find it alot easyer to get shit. ah well will all work out.
and i reckon i will run the harmonic balancer..... just dont have anything to go on the motor ATM so can go what every way i want
got a link for the differnece between running balancer or solid pully's ?
ok read up...... no point for me
T3 AE86 CAMBER TOPS FIT KE70 OK ? or suggestions on where to get some cheaper or better?
keep hearing about the caster issues some can cause.
Ive got random japanese ae86 ones in my ke70...castor wasnt an
Issue, still dialled in enough that itd break fingers if u werent careful when the wheel self centres...
MY AE86 BUILD
haha fair o .....
im running like 4 deg of castor...... daim is running somehting like 8 deg...... mine centres quick enough haha
Ordered parts from T3 today well off joel at Spirited Drive.
kuckles + tie rod
camber tops + upper hats with bearing
RCA's
should be good getting sick of all the bump steer and having NO lock
nice nice...
currently have some work happening on the ksev finally
waiting on clutch release bearing/retaining clip ex japan to arrive so i can bolt the 6 speed to my 3tc...arp flywheel bolts/lightweight flywheel and random concoction of heavy duty clutch is already bolted up...motor already has a 32/36 and extractors on it...
have sent a 2tc distributor away to be rebuilt, converted to electronic pickup and recurved...so will install that with some ignition related goodies and should wake the ole girl up a little...
diff should be assembled soonish aswell...after changing plans with the ae86, ive got a host of bits laying around...so into the ke70 they go...4.3 gears, full spool, solid pinion spacer, new bearings/seals and corona disk rear conversion
work has halted due to preparation for WTA next week, but full steam ahead in 2 weeks or there abouts...
*in other news, seems like an xExx gathering of mass proportions is scheduled in tassie later this year...not to be missed...will keep everyone in the loop...but should u have a car in the build...finish it asap...
MY AE86 BUILD
