whats the with the full motor sport discs? are they drilled?
AJPS AE86 - FC Brake Calliper Adapters
Technical information
Made in Adelaide
6160 grade Alloy from billet
Anodised satin black
To suit 262x20mm RDA rotors (DBA 4000 series available on request)
Blurb
Direct bolt on upgrade to ae86 front brakes
Does not affect offset
Stock 234x12 (18mm on JDM)
AJPS FC-EG upgrade 262x20 (slotted and plain rotors available)
Extra Details
For use with Mazda FC RX7 front callipers only. FD also fits.
AE86 brake line is ok
Will fit 14 inch wheels with large back spacing
Fitting Instructions
Fits ae86 front struts only
Weight
With calliper, hub, rotor, adapter - 8.9kg (Stock is 8kg)
Colours Available
Satin black anodise
Stock Available
10 pairs as of 14/03/08
Customer Reviews
"Fade is a thing of the past, these and good fluid and youre set for trackwork"
PRICE: $289pr
Braided lines - $189pr (ADR approved)
Rotors $189 plain $289 slotted or $440 full motorsport
Caliper rebuild kits FC or FD - $95pr
Upgraded master cyls $149
Pads QFM - HPX 0-550 $95 A1RM $125
No, theyre DBA 4000 series 6x6 slotted with heat indicators
do you still some left??
if so what does the kit come with and how much??
and what master will i need to put them in a ke70
you play halo?
add me GT: samnbhnc
Howdy mate
all the prices are for the individual parts are on the website
Yes I still have plenty left, but they sell quickly due to the advantages they have over the wilwood kit.
You can use the stock master as most people do, I also have pajero master cyls if you prefer more sensitive brakes
Send me a pm, im still trading over the holiday period
i will need a set of brackets and braided lines posted to melbourne asap
cancling your subscription as a humanoid
good brake upgrade i run these and the a big brake and cheap to
will send you a pm now
cheers sam
no worries man i always trust ur product and its been great will always come back just easy to deal with
Any idea if they fit under ma61s?
