can i see pics of the weber
FS:
1) sold
2) Weber twin down draft 36mm IDF carbs
3) 99% sure this clutch will suit smallport/20V 4ag
4) 4age 16v top timing cover and metal back plate
5) RWD conversion parts!! i.e. semi kit
6) ae86 hubs and rotors
7) sold
8) sold
9) alloy surge tank (staying with carbs)
condition:
1) usable condition
2) may have been rebuilt at some stage, throttles open and close very smoothly!
3) brand new in box
4) good, uncracked
5) all usable condition, maybe use a flick of black paint if your fussy
6) not sure what the wheel bearings are like int eh hubs, rotors maybe still fine, wouldn't hurt to be machined tho
7) used, not leaking look and feel fine to use
8) great condition, seals are good and pistons arnt seized
9) new never used or fitted
extra info:
1) sold
2) these are good when you have limited space, have seen them on a 4ac, vw boxers, V8's heaps of buses. also cheaper than most sidedrafts
3) i checked the spline and fits t-50, surface area is 112mm, OEM replacement, has some light surface rust and a bird poo because the box was left open (lol) includes pressure plate, friction plate and FWD thrust bearing.
4) covers your cam gears and shit, also includes the rubber gasket
5) this is a partial 4AGE rwd kit. includes the steel engine mounts x2 block to gear box stays x2 RWD sandwich plate (4a FWD ones are different and leave the flywheel exposed) ae86 gearbox cross member and gearbox rubber mount (needs new hole drilling to suit ke70)
6) rotors are plain stock ADM ones not JDM
7) sold
8) sold
9) good for the old EFI conversion, going from a carb motor to an EFI one (from 4kc/4ac to 4ag)
price:
1)sold
2)$400
3)$100
4)$35
5)$80
6)$80
7)sold
8)sold
9)$90
shipping: will ship
pics: by request
they are twin carbs.. they are a down draft version of the sidedraft.
will grab pics tomorrow.
LCA's pending
heaps of other parts added
still selling the rx7 calipers?? take $150 plus postage?
PM'd cerby
LCA's still available?
they are pending sold. waiting for payment which is due tomorrow.
if it falls threw ill PM you letting you know.
wat hapen to the pics
they are here
they have some crusty carbon/shit on them i started to clean one up. they are squeaky clean internally
