Results 1 to 2 of 2
Thread: 4AGE Injectors
    Senior Member Stain's Avatar
    Derek
    Far North
    Default 4AGE Injectors
    Okay.
    I've built a 4AGE smallport engine but I didn't have a smallport (AE92) dissy or ecu so I'm using a bigport (AE82) dissy and ecu to run it.
    My drama now is injectors... the smallport came with 250cc hi-ohm injectors but the bigport uses 182cc low-ohm.
    Will the engine run fine using injectors much smaller than it came with from stock?
    I've got some 210cc low-ohm, or is that still too small?
    Should I get some 295cc low-ohm 7MGE injectors?
    Garth from HR has used this setup before, I think he might have used an SAFC aswell though. I have heard rumours though of the car running lean. In my opinion I don't see why it shouldn't be O.K, with toyotas generally being very rich up the top.
    The problem is, if you used 250cc/295cc its going to run overly rich. Try the 182cc and put it on a dyno to end this mystery after all.
  • Similar Threads
    1. Replies: 2
      Last Post: 2nd September 2012, 08:44 PM
    2. 4age injectors :)
      By Drift_Donkey in forum Cars or Parts Wanted
      Last Post: 3rd December 2010, 04:45 PM
    3. 4AGE Injectors
      By cbjaust in forum Technical - Questions
      Last Post: 7th May 2010, 01:45 PM
    4. 4age injectors
      By superbmobile in forum Technical - Questions
      Last Post: 22nd August 2008, 12:28 PM
    5. 4age injectors
      By yoshimitsu9 in forum Technical - Questions
      Last Post: 6th November 2007, 08:37 AM
