Okay.
I've built a 4AGE smallport engine but I didn't have a smallport (AE92) dissy or ecu so I'm using a bigport (AE82) dissy and ecu to run it.
My drama now is injectors... the smallport came with 250cc hi-ohm injectors but the bigport uses 182cc low-ohm.
Will the engine run fine using injectors much smaller than it came with from stock?
I've got some 210cc low-ohm, or is that still too small?
Should I get some 295cc low-ohm 7MGE injectors?
Garth from HR has used this setup before, I think he might have used an SAFC aswell though. I have heard rumours though of the car running lean. In my opinion I don't see why it shouldn't be O.K, with toyotas generally being very rich up the top.
The problem is, if you used 250cc/295cc its going to run overly rich. Try the 182cc and put it on a dyno to end this mystery after all.
