ToddW
thanks for your enquiry but i have an interested party at the moment so for the time being it will go as a whole package!
will keep you posted!!
Have you given any thought about what sort of money you are chasing for the head and associated parts. I would want the whole top end. Can you let me know or PM me.
ToddW
ToddW
Paddys day bump in the forehead
Hey mate
I'm no lad here!
It looks like wear marks in the top of the bore where the piston/rings stop @ the top
of the stroke cycle.
Are you sure this block isn't just a used bore honed out with new pistons fitted?
firstly i am not your mate
and lad is a term the irish use when talking to another male of any age
so dont take offence to me calling you lad!
that is a ring of assembly lube as the top ring dosent come all the way to the top
sure you would know that if you ever built an engine "and hopefully used assembly lube"
thank you!
How many times have I told you not to mix your lubricants - there is engine assembly lubricant and sexual lubricant you appear to have used after seeing the pistons installed. Get it right!
