Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: 4.3 Ratio Diff solutions?
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Default 4.3 Ratio Diff solutions?
    Hi, planning on upgrading my diff in the future. Was considering alone the lines of an F series purely for already having 4.3's and just being strong.
    However, i learnt today that theyre about 15mm wider each side. This becomes a problem cause then i have to either
    - redo my guards and paint (again...)
    - get smaller offset rear wheels
    - raise the car slightly
    All of which i would go to ends of the earth to not do...
    Was just wondering if there is any commonly used diffs out there with 4.3's, that are the same width as a standard ke70 rear end?
    Might look into hilux or something, getting the diff put on a jig to sort it out so it fits up shouldnt be a problem...
    Any info would be great.
    Thanks Guys
    Grant
    Jonathan
    Hilux diff housing from a early HiLux. Weld your mounts on it. Diff centre from a more recent 4WD HiLux.
    Ok
    Seamus
    Milton
    Grant, occasionally there are some F-series diffs that pop up (Late 1960's!!! MKII Corona) .. it's exactly the same width as our AE/KE's, measuring in at 1410mm
    If you could get ahold of one of those it would be perfect, but they come with 4.1 ratio gears
    But you can find better ratios in the above (stolen from oldschool toymods stuff i bookmarked)
    4.30 - GA61 Celica XX manual(F285)LSD
    4.30 - MS123 Crown auto(F282)
    4.556 - MA63 Supra auto(EDM?) (F252)
    4.75 - MS57 Crown auto(F??2 - no build plate fitted)
    4.778 - MS110 crown auto(F362)
    Senior Member GOODY's Avatar
    Logan
    Bit off the topic but why wouldn't you want 4.1's? I've got 4.5's now and I'm wanting to go to 4.1 to get a bit longer gearing.
    I thought 4.3 would still be a bit too long?
    Veteran Konakid's Avatar
    Henry
    Eastern
    for acceleration.
    Shorter diff on the track means he can use third and fourth as his main gears, make the t50 last longer when youre not smashing 2nd.
    RT142 Estate.
    AJPS.
    Logan
    Ahh ok fair enough
    How much difference is there between ae86 mounts and ke70.
    none
    also you could get a diff housing cut down as well, depends how much money you want to spend.
    Calvin
    Kilsyth
    you can get any diff cut down aswell. not very expensive either. i'm running hilux 4.3 in my car and the centre only cost me 150 complete. 3rd is sooo good
    T18 in the build
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    Speak with anthony from kazien garage he is the master on f diffs!!!
    AE86 THE BEST
  1. G Series & F Series Diff Disc Brake Solutions
    By Skid_KE70 in forum Technical - Questions
    Last Post: 27th March 2019, 05:49 AM
  2. diff ratio question
    By steroidchickens in forum General Topics (No Technical Questions)
    Last Post: 9th December 2009, 10:27 PM
  3. FS: Tarago diff 4.3 ratio
    By Cerby86 in forum Car Parts For Sale
    Last Post: 2nd September 2009, 10:16 PM
  4. wtb 4.7 diff ratio,
    By brad in forum Cars or Parts Wanted
    Last Post: 24th March 2009, 07:35 PM
  5. 4.56:1 diff ratio E series diff
    By Clemo55 in forum Cars or Parts Wanted
    Last Post: 25th September 2008, 04:29 PM
