More picture, im keeen to have a lookski
this is my ke70 drift/track car is powered by sr20det
i picked it up for $150 with no motor but the rust came free!
have been doing all the work myself with help from mates and Its not finished yet but it will have the following Specs:
Engine:
- s13 sr20 redtop
- Custom intercooler piping
- alloy radiator
- T25G turbo
- Turbo back 3 inch straight through under diff to twin 3 inch straight pipes
- oil catch can
Driveline:
- 5 speed
- Custom Tailshaft
- Exedy extra heady duty clutch
- R31 diff with minispool and 4.11 gears
Suspension - Brakes:
- new s13 HSD hr coilovers front and ,rear (custom top hats and bottom brackets)
- s13 lca s
- s13 power steering rack
- s13 sr20 cross member
- custom made Castor rod mounts
- nolothane bushes through out
- protex rear disks
- stock s13 fronts disks
- white line strut brace
- kkr s13 caster rods
- camber tops
- s13 front sway bar (27mm)
- white line 18mm rear sway bar
- white line adjustable pan hard rod
- s13 front brakes
- rebuild VN commodore rear calipers
- new braided brake line and hard lines every where
- Bendix general CT pads
Body:
- Front guards cut with no inner
- rear guards inner rolled
- T18 front and rear chrome bumpers
- eBay Chrome mirors
- all rust removed and new sheet welded in
- full respray in gloss white
-14x7 0 off set Hurricane's
Interior:
- Custom sheet metal dash with drift gauges
- Custom switch panel
- hydro hand brake
- saas boss kit and steering wheel
- Fully striped interior
- 4-way Harness
- drift D1 bucket seats
- custom pedal box
Other:
- 2l surge tank
- walbro 392 feed pump
- fedro lift pump
- new 8mm hard line from back to front
From this:
to this:
motor is in but the intake manifold is hitting on the s13 brake booster any ideas?
is an r33 one smaller
hahaha no lol i just put them on to get it rolling will be running 185 50 or 60 the rims are 14x7 o offset
its got 195/65 on rear now make it look like a tractor.
must of cost a fortune so far....... in bog!
one small tin of bog half used on hole car i changed the 2 doors and guard in pics that bog work was done before i got the car all other rust spot have been cut and had new sheet welded in
Attachment 14768Attachment 14769Attachment 14770Attachment 14771
went out to tailem bend on the 21st
good fun![]()
pics dont work man
~KEEP DRIFTING FUN~
