Results 1 to 8 of 8
Thread: Frustration.
    Solo
    Default Frustration.
    Hello,
    A video says a thousand words?
    Does anyone know what's happening here:
    http://au.youtube.com/watch?v=U3GtehYadX8
    Try to accelerate but it seems to hesistate. Changed the fuel pump, map sensor and ecu. Before this problem the car was hunting, but couldn't find any vaccuum leaks.
    Any help will be appreciated.
    Cheers.
    P.S Do I need a better video?
    Jonathan
    I am guessing either very weak spark, from poor ignition components (coil, leads, plugs etc.)
    or ignition timing adjusted wrong
    or not enough fuel due to low fuel pressure (pressure regulator), or poor injectors.
    I don't really know.
    Mason
    Salisbury East
    Hey mate
    Have you done a diagnostic check with bridging ECU pin connector?
    Try that first if nothing turns up thru codes etc then look for vacuum leaks
    & check all your electrical plugs by removing the clips and checking for dirty pins
    etc.
    GL
    Senior Member adam's Avatar
    Adam
    Possibly TPS?
    My car used to hunt because the TPS was adjusted wrong and seeing that it hesitates when you're trying to accelerate/rev... it could be a problem relating to that?
    Previous ride: 4AGE powered KE70.
    Current: JZX100 Chaser and '73 Datsun 240z.
    http://twofortyzee.wordpress.com
    Dave
    yer mine did that too and it was a dudd tps, i unplugged it and it drove fine, just didnt have as much throttle response
    unplug the tps and give it a go!
    crap, i didnt see the date on this thread, as it was linked to by another tech article. and i just replied here by mistake.
    this is the more recent thread
    http://www.ae86drivingclub.com.au/fo...ead.php?t=7957
    Veteran slide86's Avatar
    Huw
    Hills
    sounds sorta like the timing is really outta wak
    TPS adjustment, coolant temp sensor and timing are the things id be looking at
    Elite rthy's Avatar
    Leo
    Tulla
    timing belt?
    was doing the same thing on my ae71, timing belt started to crack
    Solo
    Well the problem isn't yet...
    Need to get my lazy ass around it!
  1. HACHI FRUSTRATION
    By 20v Monster in forum General Topics (No Technical Questions)
    Last Post: 2nd October 2005, 06:05 PM
