Results 1 to 10 of 14
Thread: 4age jdm loom
    john
    nsw
    liverpool
    Default 4age jdm loom
    hi guys .
    just got a jdm loom off a mates wreck ... i didn't take it out myself but his mechanic did. the car is long gone and i really dont have a reference to go off .
    2 of the plugs for the ecu fits as you can see but im missing one ...does anybody know where this last plug for the ecu would be found ? i thought it would of been on the loom ..
    and also the 2 sperate remaining plug dont fit what are these for ???
    what can i do for the last plug ?
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi
    The plug that is missing is on the actual car loom which is located in the LHS kick pannel
    Senior Member rallystanza's Avatar
    Jeremy
    Vic
    Straya
    Is there any evidence of that plug actually being there?
    I know that with my BT 20Valve loom ive been putting into my AE86 that the last plug on that is all diagnostics stuff, constant 12V and IG 12V for ECU.
    Given the location of the ECU mounting in an AE86 and the close proximity to the ECU of the other 2 plugs, they may plug into your passenger side (LHS) kick panel plug location.
    Veteran Nikkojoe's Avatar
    Tom
    What 44GTE said. The other 2 plugs are for:
    White plug (only on kouki looms - zenki have this on the firewall like adms)
    Reverse Lights (red wires)
    Starter (black/white)
    Ignition power for coil etc (black orange)
    Oil Pressure (yellow/black)
    Temp (yellow/green)
    Tacho (black brown dots)
    Yellow Plug:
    Wiper and washer motor wires (all the blue wires)
    EFI Main Wire (black/red, comes from the engine bay fuse box area - should be a 2pin black molex connector near the coil with the black/red wire) - This gives power to ECU, Fuel COR, Fuel pump.
    Other wires are just for diagnostic i think (brown an earth).
    Mason
    Salisbury East
    No mate
    those 2 left over plugs go in the kick panel area for heater fan control
    & instrument gauge sensors etc!
    If you car doesn't have the plugs in the kick panel area then you will have
    to trace them thru the loom.
    Tom
    No heater fan control in those plugs, only what i mentioned above.
    If its an adm, it definately wont have those plugs in the kick panel.
    john
    nsw
    liverpool
    had a qiuck look last night .. and the problem is not as easy as i first thought it would be ...
    i bought the car with a miroctech in it. tuned for the motor it currently has
    (4agte) . long story short i now cant drive turbo cars ... until im on my fulls. so i thought it would be a eay plug and play ... take all the turbo gear off and swap over the mircotech loom with the standard loom ....
    so far i have gotton up to the stages in the picture .. it looks like im going to have to find a wrecked sprinter and gut out the body loom ...
    anybody have a body loom or wrecking a sprinter ????
    Veteran slydar's Avatar
    Dimitri
    if you wanna do it that way you would need a kouki jdm ae86 dash loom. zenki wont work, its no compatible, to the point of which it will actually cause a short and possibly catch on fire
    but. adding the 14 pin plug is fairly easy, if you can do it yourself it wont be too had to find someone who can, and should only cost you $300/$400. the plug itself is common, you can get it from toyotas ae82 twin cam, any efi ae9x series corolla, might be grey but still plugs in and works, camrys ect ect.
    from the same car, grab a circuit open relay, and thats all you need... plus some one to wire it.
    Tom
    If you can't find a Circuit Opening Relay (COR), 2 relays can be used.
    Slydar - What part of the loom would short. You talking about the 3rd ecu plug? I know there are some extra pins on the kouki loom, but I can't see anywhere else that would be a problem.
    john
    nsw
    liverpool
    http://www.club4ag.com/faq_and_tech_...86%204A-GE.htm
    found this while googling ... its not good but a start, so i figured the last plug into the ecu is 14 Pin Socket
  1. Jdm 4age bigport loom
    By Savtec in forum Cars or Parts Wanted
    Last Post: 14th February 2011, 02:27 PM
  2. JDM Rwd 4age Loom
    By deanoo in forum Technical - Questions
    Last Post: 4th April 2010, 05:52 AM
  3. JDM 4age loom, ecu and other bits
    By Nikkojoe in forum Car Parts For Sale
    Last Post: 12th March 2010, 12:34 PM
  4. Jdm 16 4age engine loom?
    By Tyrael in forum Cars or Parts Wanted
    Last Post: 30th July 2007, 07:40 PM
  5. Jdm 16 4age engine loom?
    Last Post: 26th July 2007, 08:52 PM
