Cheers guys.
Hachiko its a curse! The only thing of semi value in my life are two half built hachis
Nice work mate.
Cheers guys.
looks dope
loving the meisters!
Yes, Meisters get me high too!
Thanks
Nice work dom.
Glad you are happy with the meisters
Thanks Guesswho. The wheels are the perfect addition to the build.
I got some stuff done today, GREAT SUCCESS!
I painted the windscreen surrounds.
...and also painted the SR rocker cover after grinding down the writing first.
Its a little rough because I done it quickly. After the grinding I sprayed high fill primer over the rough bits and then applied the paint straight on top before it dried.
And the end result with the clear still drying.
This morning I went to KYP to play with the front suspension to fix rubbing issues.
I moved track out about 15mm each side with positive results.
All of the wheel rubbing is gone.
....but this is worrying...
The lock stops when the rack ends hit the LCA's.
Anyone else have this problem???
But this had me giggling like a little girl
Obviously the settings are still up in the air, pardon the pun, as the motor and gearbox need to be in and it needs to get properly aligned, but it should be ok I think.
And I was happy the wheels fill the CBY guards too.
Please let me know if you have any helpful hints on my rack end problems.
Thanks!
Just thought I'd add, currently track (measured from wheel mounting points) at the rear is 146cm and front is 153cm.
I rekon it wont be a problem untill you look at it on the ground with all the weight on the car, looking damm good tho mate! keep it up
Cheers mate.
Yeh your right, I'll have to wait till all the gear is in. Apparently it's pretty normal.
fukin crazy man... very nice
looking very hot mate,
keep the pics coming!
