Results 1 to 10 of 14
Thread: Dry Cell Batery - smallest ?
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Default Dry Cell Batery - smallest ?
    Just a quick question for anyone that knows...
    What would be the smallest dry cell battery I could use in the 86? (or more so in an automotive application in general)
    brand/CCA/price if you know these things also..
    Niz.
    BENT MECHANIX - Garage 20:
    Niz
    South~Slide Briz
    looking at these, they look pretty tight' not to sure if there is much smaller on the market?
    http://www.pulsehyper.com.au/phb400.htm
    Jonathan
    I have a generic dry cell motorbike battery here which I got for that purpose. $50 at SuperCheap. It's a 15AH. I hadn't tested it yet.
    Got another battery the same which was out of a jump starter pack, its at 17AH. Probably on the small side, but may work.
    Odyssey are the respected name in motorsport for this, but I'm sure lots of generic drycel batterys made for computer backup and security systems work as well.
    Niz
    South~Slide Briz
    yeh I was wondering if a motorcycle battery would have enough juice to do the job...
    excuse my noobness here.. but what does 'AH' stand for ?
    Jonathan
    Amp Hours.
    How big is big enough maybe due to the weather and distance you go from home etc.
    You don't see many AE86s on the Japanese sites with a small battery. Maybe due to their cold winters.
    For a full N2 setup, I think you can go with no battery at all. Carbies + CDI.
    Veteran biggo's Avatar
    Nick
    Noosa
    Amp hours
    Mate has a smallish pulse battery. 250CCA or some thing stupid. I woulkdnt rate them as it can barely start an sr20 at full charge plus itd be dead in a week hahaha
    Veteran slydar's Avatar
    Dimitri
    i use a deka brand battery. its the same size as that pulse one you have pictured there. and like the "small" odyssey one. its an absorbed glass mat battery. still fully sealed. and yeah used in jumper packs and boats. $80 at the wholesaler. call me if you want man ill let you know where the shop is, cant remember the road right now, but its on the south side close-ish to where you said you lived.
    Niz
    South~Slide Briz
    amp hours ---- I see..
    Well basically I need something dry cell so it can be 'legally' mounted in the car and it has to be able to hold charge for a week and start the car without any dramas... that's about the only requirements.
    I want it as small as possible to save weight where ever I can pretty much.
    Niz
    South~Slide Briz
    Quote Originally Posted by slydar View Post
    cool.. I'll discuss with you when you come do that welding for me if I remember....
  1. Odyssey Dry cell battery PC680
    By reecegze in forum Car Parts For Sale
    Last Post: 31st January 2010, 09:22 PM
  2. What's the smallest exhaust pipe you would use?
    By Grant #2 in forum Technical - Questions
    Last Post: 1st August 2009, 01:32 PM
  3. Smallest 4A
    By Adsie in forum General Topics (No Technical Questions)
    Last Post: 23rd February 2009, 09:12 PM
  4. Dry Cell kits ..
    By redsprinter in forum General Topics (No Technical Questions)
    Last Post: 26th December 2008, 11:06 PM
  5. Charging a Dry-Cell
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 21st March 2008, 06:51 PM
