Results 1 to 10 of 10
Thread: So i think my cars fucked
    Senior Member quadeyquade's Avatar
    Quade
    Default So i think my cars fucked
    lol i think my smallport is dead
    http://tinypic.com/player.php?v=2ilop42&s=5
    that ticking is the idle..
    Jonathan
    Yeah mate. She's fucked.
    Conrod bearings.
    todd
    broken.
    i think it died of dysentery
    Quade
    Quote Originally Posted by Jonny Rochester View Post
    Conrod bearings.
    So you reckon the head is fine?
    Quade
    also, should i put a brick on the accelerator and watch it pop?
    Jonathan
    I don't think the brick is needed. You can still rebuild it. You just have to pull the motor down to every last bolt, inspect everything and start again. If you don't drive it any more the crank maybe fine. Send crank, conrods and pistons to the machine shop to get checked.
    Quade
    how much gold pieces does a rebuild cost these days?
    Jonathan
    Get on the spanners yourself as much as posible, it saves a lot of money.
    Maybe you can pull the motor out, pull all the manifolds and accesories off. Give the machine shop just the bare motor, which is block, sump, head, cam covers, timing belt.
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Strip your motor, take it to the shop and get what we call a "strip and quote" and go from there depending on whta price they give to fix it and your budget.
    Full rebuild is well over $1000, but if it's a spun big end, maybe you an get the crank ground and the offending rod big end resized, get the appropriate sized bearings and put it together yourself if you feel confident enough.
  1. DA Fucked again...
    By ae8zn6 in forum The Drift Channel
    Last Post: 17th May 2010, 09:58 PM
  2. proper fucked
    By fantapants in forum Technical - Questions
    Last Post: 29th April 2009, 02:32 PM
  3. gearbox fucked?
    By dr1ft-pig in forum Technical - Questions
    Last Post: 9th October 2006, 03:52 PM
