Results 1 to 9 of 9
Thread: t series Diff question.
    Stuart
    nsw
    stanwell tops
    Default t series Diff question.
    I have a t series out of a t 18 but the housing is bent, i want to buy a jdm disk brake housing. will my axles an centre bolt into the jdm housing ?. ( the axles out of my t-18 are not bent just housing)
    thanks.
    john
    nsw
    liverpool
    they are interchangeable . but the jdm axle bearing might need to be replace jdm disk t-series normally run the bigger bearing (twice the width of the drum t-series)
    in saying that. if the axle are still in the bent housing i would check the axles aswell.
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    id just search for another t18 diff will be cheaper, disk type bearings will prob cost half the price of another t18 diff.
  • #4
    Veteran Todd's Avatar
    Feb 2010
    Todd
    SOR Perth
    i was lead to believe that t18/jdm zenki drum T series axles CANNOT be interchanged with their disc brake counterparts because the housing flanges are different?
  • #5
    Stuart
    nsw
    stanwell tops
    the axle that was in the housing when i hit a gutter LOL was bent but replaced it.
  • #6
    Dave
    Western Suburbs
    pretty sure todds speech is also correct, best off sticking to t18 its overall cheaper just get a zenki 2way
  • #7
    Vancouver, BC
    Downtown
    Canada
    Quote Originally Posted by Todd View Post
    You're right, the flange has a different bolt pattern, but if you're changing the bearing to a double row bearing just replace the flange at the same time. If you don't get the flanges with the housing this could be problematic!
  • #8
    Stuart
    nsw
    stanwell tops
    If i brought the jdm housing would i be able to change the flange back to the drum flange an run drum brakes, i can't get standard t series housing but i can get a jdm housing an i need mt car back on the raod thanks...
  • #9
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    if the JDM housing your reffering to ran disks, then no, you wont be able to run drums.
    - unless you get the drums redrilled to suit the pattern on the jdm housing.
    best off finding a stock adm t18 housing.
    Filip.
  • Similar Threads
    1. Replies: 0
      Last Post: 1st July 2012, 01:36 PM
    2. Replies: 14
      Last Post: 4th June 2012, 07:16 PM
    3. T-series diff question
      By E7 PIG in forum Technical - Questions
      Last Post: 21st June 2010, 08:45 AM
    4. t series diff question
      By eightsixboy in forum Technical - Questions
      Last Post: 13th April 2008, 12:35 PM
    5. s series diff question
      By shinny in forum Technical - Questions
      Last Post: 15th September 2007, 06:49 PM
