Results 1 to 5 of 5
Thread: AE86 Clutch Master and Slave cylinder
    Tom
    SOR
    Default AE86 Clutch Master and Slave cylinder
    Anyone got part # for them? Also anyone know if the JDM slave cylinder the one on the driver side the same as the Aus slave cylinder?
    Gone
    Joel
    Picton
    the clutch slaves would be different - dont have a part number
    Senior Member Dylan's Avatar
    Dylan
    Parts catalogue shows there the same number but they look different
    PBR lists these numbers:
    ACTUATION Clutch M/Cyl 07/1983 - 12/1985 COUPE, 1.6 LITRE, 15.87 mm , PN = JB1490
    ACTUATION Slave Cylinder 07/1983 - 12/1985 COUPE, 1.6 LITRE, 20.64 mm, PN = JB4149
    Tom
    SOR
    Thanks Dylan, the slave does look different. I was told that a clutch slave from a T18 is the same as JDM clutch slave can anyone confirm this?
    Aaron
    i have the part number listed at work. i know they are available from toyota tho but cost about $80. failing that you can go to somewhere like perth brake parts and they can rebuild it for you. but yes the jdm and adm are different. the bleeder are on opposite sides.
    master cylinders can be purchased from pbr and are around the $35 mark. you can just go to repco/whatever and say give me one for an 86 and they will get it for you
    however you do need to modify them a bit to get them to work properly.
    i found with all the ones i get from pbr you have to cut the thread down and retap about another 1cm worth of thread onto the pushrod. if you dont the pushrod fouls on the clutch pedal before you even get to adjust it up. and even after you do cut the thread down there isnt enough thread to adjust it still
  1. WTB ae86 clutch pedal, slave,master and lines
    By cressidways in forum Cars or Parts Wanted
    Last Post: 23rd August 2011, 12:17 AM
  2. slave cylinder for w58/button clutch 4agte ae86
    Last Post: 28th September 2008, 10:50 PM
  3. AE86 clutch pedal assembly with Master and slave.
    By Rallystanza in forum Car Parts For Sale
    Last Post: 23rd July 2007, 11:24 PM
  4. WTB: Clutch Master Cylinder AE86
    By drif86s in forum Cars or Parts Wanted
    Last Post: 14th April 2007, 09:18 AM
  5. 4age Slave master cylinder
    By xsoarerx in forum Technical - Questions
    Last Post: 30th March 2006, 07:53 AM
