Results 1 to 10 of 10
Thread: EOI/FS - Kouki trueno 4AGZE project
    Default FS: (NSW) Kouki trueno 4AGZE project - SOLD
    1985 Kouki Trueno GT-Apex (full power options)
    SOLD
    This is what it use to look like when first got it.
    The ducktail and sideskirts and front bar are basically trash, rear bar could probably do with replacement too.
    Obviously now it looks nothing like that as it is in primer and has been 70% finished panel beating.
    I suspect someone hardworking and competent could get this thing ready to be sprayed in no more than a few weekends.
  • #4
    No one at all is interested in doing a little work and saving a few grand?????
    JDM Truenos with standard a 4age seem to be going for 12-15.
    This has a 4agze conversion.
    All it really needs done is:
    + Rear drivers section under the tail light finished,
    + Thin panels under the doors worked on (but would be covered by sideskirts if you choose too anyways),
    + Flared lips on the front fenders smoothed down and evened out (or could opt to replace with frp fenders).
    + Final rubdown and fresh coat of paint.
    + Then compliance and rego.
    Make an offer!
  • #5
    No offers at all?
    Go on! Make an offer!
    The Trueno project
    OR
    The Trueno project + aus-spec ae86 with 1 years rego.
  • #6
    Back to the top
  • #7
    Veteran slydar's Avatar
    Dimitri
    dont think youve listed a location.
    you also need to give details of the suspension and whether or not it has an LSD. most potential ae86 buyers are pretty interested in that.
  • #8
    Senior Member OMG866's Avatar
    Nick
    Miranda
    dudue swaps. check the non toyota section
  • #9
    Thanks slydar!!! I am such an idiot!!!
    Located in Newcastle, NSW
    And thanks for the suggestion OMG866....
    Being a jap kouki trueno it has the kouki T-series axle set which are a little larger than the zenki I believe, not sure if it has an aftermarket or standard LSD though, but it has some type of LSD I am sure.
    Suspension, don't think it has any suspension work like coilovers etc, just springs of some sort and adjustable shocks.
    Right now I am prepared to get ride of BOTH the Trueno project and aus-spec at 8K, or neg.
  • #10
    bump...
  • Similar Threads
    1. Replies: 18
      Last Post: 30th October 2007, 04:20 PM
