i doubt it... gap would be different. new plugs aren't that expensive, go and buy some NGK's.
Are 4A-FE plugs OK to use for a 16v ?
Cheers.
buy ngk-r
race spec haha
yep, thats what i use. can tell a difference between ngk and bosch for sure.
hows the price of the r's compared to normal, havent really looked into it.
A 4A-FE is a 16 valve.
4A-FE plugs should work fine in a 4A-GE if that's what you have.
i hope you dont just assume the gap is correct when you buy them.....even if they are specifically for 4age.
- Blaise Pascal
I've never checked plug gaps? I'm guessing a multi-national company like NGK would have quality control good enough to ensure that the product inside the packaging is what the packaging says it is?
from memory a smallport is 0.032.
i think i paid just under $20 each for laser platinum.
