Results 1 to 8 of 8
Thread: help where to get lamp failure unit.
    Sep 2009
    Speed
    Queensland
    Crestmead
    Default help where to get lamp failure unit.
    hey guys does anyone know where i can get my hand on a lamp failure unit, i've got no brake lights and i've traced it back to this box i found in the boot. part number is 89373-32020 any help would be great.
    Dave
    do you know what the box does?
    i assume its for an ae86, and they have a brake light failure light on the dash?
    i think the little box is just a current sensing thing and if no current is being drawn then the little indicator turns on? (letting you know your brake lights arent working)
    if you are sure that the little box is at fault you might be able to just omit it from the system....unless you really want your little indicator light to work etc. would take a bit of playing around with a multi meter etc.
    - Blaise Pascal
    Sep 2009
    Speed
    Queensland
    Crestmead
    yeah i did want it to still all work but im not liking my chances of finding one as its a discontinued part.
    looks like im going to have to bypass it.
    Senior Member cbjaust's Avatar
    looking at the circuit diagram, it looks like you can just bypass it. The wire that goes into the box from the brake pedal switch is Green/White and the same colour is listed as coming out of the box and on to the brake lights. So have a look and join the two ends up to bypass the box.
    Sep 2009
    Speed
    Queensland
    Crestmead
    yeah just bypassed the box cheers guys working all good now. would still like to try and find another one tho.
    They seem to be specific to the Japanese EFI AE86s
    Senior Member racsov's Avatar
    Nick
    West
    Lamp fail.
    Anthony
    ^^ lol
    try one from an mx83 or ma70. might see one of those at a wrecking yard.
  1. Head Lamp Wiring..
    By hitoriko in forum Technical - Questions
    Last Post: 1st March 2009, 08:52 PM
  2. Replies: 2
    Last Post: 11th September 2008, 06:53 PM
  3. Corner lamp relay?
    By IanJ in forum Cars or Parts Wanted
    Last Post: 24th July 2007, 07:02 PM
  4. brake failure
    By DriftPlease in forum Technical - Questions
    Last Post: 10th April 2007, 06:23 AM
  5. shift lamp
    By jono86 in forum Technical - Questions
    Last Post: 23rd August 2006, 08:34 PM
