Results 1 to 10 of 19
Thread: Reversable?
    Dan
    Vic
    Western Subs
    Question Reversable?
    Hi guys
    i just got a pair of rims (see pic) and i want to know if there reverseable is there anyway to tell from the pic? im getting them tomorrow but i just want to know as im going to clean the centres and the lip and paint them but are they reversable?
ID:	1182   Click image for larger version.
Name:	volk rims2.jpg
    Senior Member 45aken's Avatar
    Marko
    They could be,
    but there is no way in hell i would reverse a wheel with that much +ve offset.
    awesomely unsafe
    Senior Member Beck's Avatar
    Andrew
    I can see how they might be funny looking, stick out too far, and quite possibly illegal with that much offset, but why unsafe? Or do you just mean unsafe in how far they'd stick out?
    Senior Member riceburner's Avatar
    dont look like they'd be that safe if reversed... also is there a buckle in one of them in the pic on the right???
    Insert witty comment here....
    Andrew
    But WHY do they look like they'd be unsafe? From my thinking, you've still got the exact same amount of weight on the exact same spot in the rim... from a pure physics standpoint, the wheel wouldn't even know that it'd been reversed, if you get what I mean.
    But again, if it's just a matter of them sticking out too far, making them unsafe... that I'll buy. And yeah, there is a bit of a buckle in one wheel it looks like.
    Steve
    Cairns
    The wheel might not know, but the wheel bearing will. You may hear its screams of protest as it collapses under the load. Think levers. The more negative you go, the more wheel vibration you'll get too - unless you're willing to clip weights to the outside.
    Veteran Dom86's Avatar
    Dom
    Balga
    way too much stress on the bearing and the wheel. By the looks of it you'd have about 2inch on the inside and at least 4 on the outside.
    This means all of the wieght of that side of the car will be on the inside of the wheel. Vary dangerous.
    It a differant story with positive offset.
    With negative offset the rim is always near 50 50 on both sides of the center or more to the positive offset.
    you will understand when you put the reversed wheel on and see just how little of the breaks are in the wheel.
    Hope this helps.
    The Track Car Build: Indigo
    A Heap Of For Sale: The Heap
    Dan
    Vic
    Western Subs
    cool
    yeah there is a buckle but its not bad at all looks more like someone just cliped the gutter as apposed to slammed into it
    but thanks all
    i wasn't planning on reversing them but just wanted to know
    E-Famous (Remeber your roots)
    Fuck that.
    You can. But don't.
    Andrew
    Ahhh, of course. So simple when you think about it that way. Cheers.
    Because race car.
