Results 1 to 6 of 6
Thread: Water leak without tailight rubber seal??
    Pun
    Bkk
    Bkk
    Thailand
    Default Water leak without tailight rubber seal??
    Hi, I need some advice here.
    I found my Hachi has water leak into the rear & flood spare tire room. I just got my body paint fixed, rusts are gone & I already made sure there are no holes anymore. So, I traced down to where water came from I ended up at Taillights.
    This is what I just realized: my taillights do not have any rubber seal, so water could leak through it.
    - Does anyone ever experience water leak like this? (I might be wrong with the seal)
    - Any recommendation for alternative solutions apart from fill up with silicons?
    - New Rubber only comes with a new set of taillight, isnt it?
    Thanks,
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    lol, sikaflex them in. its pretty common with cars around this age, the old seal is usually corroded and needs to be fixed. sika flex or sillicone aroudn them will sort out any problems you have.
    FTP.
    Steve
    Cairns
    Water most definitely will leak in around there. The seals on mine were perished, so I used a roll of foam tape from Clarke Rubber to create new seals. Advantage is, when you want to remove them again, they're not glued in with silicone.
  • #4
    Veteran Nikkojoe's Avatar
    Tom
    What 86coupe said, they use foam from factory so why use silicone. You can also get the stuff from bunnings, cost me like $5 for 3m
    That said, im pretty sure you can get new seals from toyota, its called a tail light gasket from memory (yahoo japan has them brand new sometimes).
  • #5
    Pun
    Bkk
    Bkk
    Thailand
    Thanks guys, probably foam tape is a right option for me at a moment, I never thought of it...!!!
  • #6
    just use some black silicon stuff.. when you want to take them lights out again they will come out its not like their stuck in.
    Foam tape will always leak I find
  • Similar Threads
    1. Wtb 86 boot rubber seal
      By Gear-head in forum Cars or Parts Wanted
      Last Post: 11th June 2012, 11:17 PM
    2. KE70 Rear end cut off + rubber boot seal SA - Adelaide
      By troyboy in forum Car Parts For Sale
      Last Post: 30th December 2010, 02:49 PM
    3. Water Leak-When it rains
      By Slimer86 in forum Technical - Questions
      Last Post: 27th August 2010, 09:54 PM
    4. 3tc water leak?
      By Hazzard in forum General Topics (No Technical Questions)
      Last Post: 16th July 2010, 01:06 AM
    5. Rubber weather seal top of firewall - ae86
      By NIZLAH in forum Cars or Parts Wanted
      Last Post: 17th October 2009, 04:59 PM
