hey mate do they just bolt straight up?
Sold!!
~KEEP DRIFTING FUN~
yep, they do
~KEEP DRIFTING FUN~
To bolt 'straight' in:
1) Will need to use the KE70 upper hats as the XT130 ones are a different pattern. (Or Ae86 camber tops)
2) Also will not bolt straight onto KE70 steering arms. Will need to use the XT130 steering arms or AE86 (PS would be best).
3) IIRC new flexi brake lines as the stock caliper has a differnt fitting to the 2 spot Sumatomo Corona calipers.
i have ke70 top hats, and you will need other steering arms, easy to get xt130 lca's and steering arms, and my bad they are not twin pistons sorry, but still good
~KEEP DRIFTING FUN~
funny cos in my experience the xt130 struts have a different bolt pattern to ae86. I had ae86ps arms and i ditched the hilux,pug,xt130 upgrade in favour of rx7 upgrade because i didn't want to have to change to xt130 arms.
this is also true, you cant use 86 pwr steering arms but who cares, they are a budget upgrade and have worked very well.
buy them, someone
~KEEP DRIFTING FUN~
Bumpy bump
~KEEP DRIFTING FUN~
thats what im saying though, if it doesn't work with 86 steering arms then it should work with ke70 arms!
i used xt130 arms, work well
~KEEP DRIFTING FUN~
