Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Technical Question
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    Default Technical Question
    for the time being until one is made up i thought we could use one in offtopic?
    Dave
    Western Suburbs
    anyway my question is... i have recently put coilovers in... and im running wheels with the specs 14x6.5 +10 185/60 and the tyres almost scrub against the adjustable rings on my coilovers giving about 1mm of space between, they scrub on full lock, and im planning onputting 15x7.5 -5 with 195/50's im wondering how can i oversome this problem maybe shaveing down the adjustable rings ? just wondering about offset too cause that will bring wheel closer to the rings ?
    please help me out want this done just after christmas
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    the new offset the wheels will be about 1-2mm further away from the struts i reckon.
    maybe run 5 or 8mm slip ons until you can work out something better?
    Formerly known as grape_moosha
    Dave
    Western Suburbs
    so negative offset will bring tyres further away from the adjustable rings on my coilovers ? i thought it would bring it closer ? i must be thinking opposite way of offset then
    Alex
    Northfield
    negative offset will bring it further away, but because your also going for a wider wheel it wont bring it away by much.
    Dave
    Western Suburbs
    yeah thats fair enough now i need some wheel king to calculate since thewheel is an inch bigger than the current how much will the difference be exactly between +10 to a -5 with 6.5 to 7.5 inch diff
    Veteran bigm's Avatar
    Gold Coast
    28mm Extra track (outside of the wheel)
    2mm More Inner Clearance
    The best website for working out wheel fitment:
    http://www.1010tires.com/WheelOffsetCalculator.asp
    Dave
    Western Suburbs
    hey thanks man, now anyone recommend a minimum clearance ? 5mm ?
    Gold Coast
    5-10mm
    depends on what tyre you are running, but if its a 195/50 on a 7.5 it recon it would be fine. if not just slip on spacers would do the job
    Dave
    Western Suburbs
    yeah trying to avoid spacers as a few people say their dangerous and my dad seen too many mini's in his days with slipon spacers with wheels flying off, still considering grinding down the spring adjusters a few mm, id love 10mm gap but dont realisticly see how im going to get it
  1. AE86DC Technical Documents
    By Nicko in forum Technical - Articles
    Last Post: 29th October 2015, 06:42 PM
  2. Really technical question for trueno owners.
    By UNDRGRND D0GF1GHT3R in forum General Topics (No Technical Questions)
    Last Post: 9th November 2007, 04:21 AM
