Hi , fully rebuilt a/f parts on 4agze smallport bottom end , bigport head with works - custom inlet manifold ,cams/gears + 70mm t/b compression around 9.4:1 and with a/f ecu can yield 269kw on 23 psi. Thats with gt30 series turbo and custom .49 rear. Lag is up to around 0rpm to 4000rpm and full boost by 5500rpm.
This setup would be horrible on the street and this is in FWD format also.
Should give rough idea of the 300kw mark
l
