not sure, this was 4 my 86.
whats needed to put into a ke70
sorry dont no much about diffs
to fit in a ke70 with stock k (k50 or k40)series box you need a complete series 1 t18 tail shaft, if you have a t50 gearbox you need front ae71 tailshaft half an the rear t18 tailshaft
you will not be able to fit this into a ke70 because the tailshaft from ae71 and ke70 are 1 piece you cant unbolt them this will only suit some1 with a 4age in their ke70 with front section tailshaft from sprinter and rear from t18
btw is there any float in the center? cheers mat
the dyno pull to 300rwkw
series 1 t 18 shafts(23 or some crap) have the same spline an size count as k series boxs so it can be fitted into a ke70. third last post
i pulled it apart to fit the lsd straight away so im not sure bout the "float"
hewy mate still got the diff for sale?
I swear my Tailshaft in the Ksev is 2 piece Bro.
It bolts to chassis half way, has a rubber grommet bit. surely you unbolt both halves from there?
i know the KE30/55 is one piece solid tube from gearbox to diff.
Anyone get the License plate of that B& Hammer?
Hi Dave , I will take the diff if we are talking about a housing ,diff and drum breaks.
Bob
i still has demz diffs
