so my 14'' longchamps fit straight over these with a small slip on spacer
what are these replacment rotor?
You have a pm sir.
Edit.
Hi Joel
You have some PMs regarding the brake kit that was delivered.
Sundee - Can you please provide a quote to me at the current exchange rate?
Cheers.
Does this work well with the stock master cylinder and booster or is an upgrade of those components recommended aswell?
Negative, no upgrade is required
hey all, i was wondering if someone could give me the measuement from the flat part of the hub to the edge of the caliper as i'm trying to figure out if my 15inch rays mesh will fit? also do you leave the backing plate on when changing it over or do you take it off completely?
Cheers Wade
Pls pm me for the current pricing of the wIlwood kit and posted to 0828
Vener
Posted to NSW 2323, how much you want Sundee.
