Results 1 to 10 of 14
Thread: ca18det pistons in a 4agte
    c
    Veteran shift_rook's Avatar
    SE Burbs
    if ya gnna do it piut some mad forgies in there... otherwise i don't see the point in just factory shitters. that's just my opinion anyway
    for a turbo engine definately not reccomended...u do realise how thin the bore will be once u manage to fit a ca18 piston? also the fact compression will be rather high aswell...
    im definately no engine builder nor a tuning wizz..bad idea all around which ull find when u actually research it properly...
  • #4
    what is the bore diameter of ca18?
    is it fit the 4ag20 connecting rod?
  • #5
    Nathan
    Lilydale
    i think ive read the that the ca piston is 83mm?? cant confirm though.
  • #6
    Veteran slydar's Avatar
    Dimitri
    no.
    stock 4age is 81. ca18 is 83. max factory recommended over bore is 82.
    some people go to 83 in na engines, to try to squeeze some extra power out, but its not necessary with a boosted engine.
    also, ca pistons are cast. 4agze are forged. stock ze pistons are better.
  • #7
    currently i am using smallport piston.
    will the ca18 piston make compression ratio higher or lower?
    i plan to stay NA for sure.
  • #8
    Dimitri
    if you use a ca18de one it will probably make it higher. its an ok idea, but the webbing between 2 and 3 gets real thin.. like as in the engine builder ive spoken to about it said you would really need to get the bores sonic tested.
  • #9
    thanks Slydar. sounds interesting but a little bit risky.
    any bad experience on this modification? please anyone share...
  • #10
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    ze pistons are ceramic coated semi forged things, ca ones are cast = shit
    AE86 THE BEST
  • Page 1 of 2 1 2 LastLast
    1. Replies: 4
      Last Post: 13th September 2013, 02:17 PM
    2. 4agte bottom end weisco pistons, h beam rods
      By 350hp4agte in forum Car Parts For Sale
      Last Post: 23rd October 2009, 09:24 PM
    3. Replies: 6
      Last Post: 15th July 2008, 08:28 PM
    4. ca18det t28 turbo and ca18det manifold siut t3 t4
      By joshnz in forum Car Parts For Sale
      Last Post: 18th December 2007, 07:47 PM
    5. CA18det vs sr20det vs 4agte into ae86
      By tipper86 in forum General Topics (No Technical Questions)
      Last Post: 28th July 2007, 10:29 PM
