Results 1 to 10 of 10
Thread: radiator lower than motor. how to get it to flow?
    Senior Member 70wagon's Avatar
    Jarrad
    Barossa
    Unhappy radiator lower than motor. how to get it to flow?
    hey all
    i have a question about my radiator it goes like this
    my motor sits about an inch or more higher than my radiator so im guessing it wont feed the coolant thirsty motor so....
    1.will it flow?
    2.will i have to make a tank of to the side the same hight as my motor to get it to feed the motor easy enough?
    3.any other ideas?
    cheers jarrad
    Jonathan
    The height difference is not a problem once things get going. It will flow, because you have a water pump. Everything is under pressure, the pump does its job, gavity has little effect.
    The problem is, when you fill the motor, you need to get all the air out of it. If the rad cap is not at the top of the system, you need to put a tap or bleed nipple at the highest point.
    Senior Member Simon-KE70's Avatar
    Simon
    making a swirl pot could be your solution here, cheap and 100% effective.
    Jarrad
    Barossa
    thanks jonny i plan on trying that strait away!
    i would make a swirl pot by having a pipe the same hight as the radiator and one the same hight as the motor yeh? just in to a sealed chamber basicaly a bit bigger than a chatch can?
    thanks for your help guys!!
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Or just jack up the front of the car high when you fill it up... problem solved.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    golbeg, you still want an air bubble to form in the radiator before the head. This is why VL heads crack all the time
    go the remote filling point
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Quote Originally Posted by Sam-Q View Post
    second that there is 1 you can get with a little filter element in there that will help you out alot works a treat on the VLs
    the dyno pull to 300rwkw
    Endeavour Hills
    whats the filter do?
    Simon
    you wouldnt need a filter in a cooling system, in fact it could do more harm then good. If it blocked up which it would since the cooling syst is hardly a clean environment. then it would restrict flow and cause overheating issues. no need for a filter IMO
    Endeavour Hills
    I was asking because the comment was used in the original context of talking about coolant bleeding. If its just for filtration I dont see the point
  1. WTB JDM Radiator over flow bottle.
    By hachirusto in forum Cars or Parts Wanted
    Last Post: 16th August 2012, 07:17 PM
  2. Replies: 22
    Last Post: 25th August 2011, 03:15 PM
  3. WTB: AE86 lower/upper radiator brackets
    By munki in forum Cars or Parts Wanted
    Last Post: 23rd June 2010, 03:24 PM
  4. 86 lower radiator support!
    By julzy in forum Cars or Parts Wanted
    Last Post: 6th October 2009, 05:53 PM
  5. [vic] t-18 radiator for 3tc motor
    By tuff te-72 in forum Car Parts For Sale
    Last Post: 14th September 2009, 02:17 PM
