what bellhousing?
Just converted my gear box to a w58 in my ae86 with a 4agze turbo. It works fine on 5psi flicked to 12psi and the car made all the right noises - clutch slip. I have a exedy HHD clutch kit and sports organic clutch the one under brass button, its meant for a carona on a 200mm flywheel. also just changed the master and new lines.
What have other people used with flywheel size and what clutch, my w58 has a 21 spline 29.8mm shaft by memory and i have 200mm and a 212ish but i thinks it 220mm flywheel. will go back to brass button but mainly a street car
thanks Greg
what bellhousing?
Niteparts from NZ
i have a dellow and gonna try fit a gze flywheel and custom clutch... is it impossible??
be very careful with your thrust bearing spacing when you put it together. I wonder if they fixed the angled gearbox problem.
the gearbox is on a slightly to the left, however the guy at the clutch place came across a 212mm, 21 spline 29.8mm Cushion Button from excedy not for a toyota gearbox ill see if i can get the model number. the cars boosting again very well
