Results 1 to 10 of 10
Thread: Nissan 4 spots on AE86
    Sutherland
    Default Nissan 4 spots on AE86
    Hey guys,
    I once owned a 86 which had nissan 4 spots on it and was wondering if
    anyone still makes the adapter for the calipers or if the AJPS RX7 ones work.
    I would just do the RX7 setup but I already have the Nissan calipers.
    Any help or links would be great.
    Cheers, Ben
    Site Supporter Javal's Avatar
    Josho
    Slide86 has converted to filthy nissan S14 calipers. If nissan calipers share the same bolt spacing (which i believe most of them do) then you're set.
    PM him or look up his old build thread on the old forum.
    Sutherland
    Thanks mate
    Veteran johl's Avatar
    Johl
    realistically will the greater braking power of r32 brakes over fc be wasted? i mean with our cars being so much lighter you can only slow down so fast?
    Sutherland
    I agree 100%, if anything brakes bigger than FC will more than likely overbrake a 900kg car with camber and 195 tyres. I'll take AJPS advice and go FC setup.
    Thanks for your help
    User fantapants's Avatar
    Pat
    i kinda thoiught all the 4 pots were made by the same crew anyways??? sumumoto ?? or something like...so the fc, subaru and nissan etc etc are all basically the same, but bolt spacing and offsets differ.... mainly confused in terms of the "more powerful nissan setup" statement
    06/07/2011
    Sutherland
    Well, Can anyone confirm i the FC and Nissan caliper share the same bolt patern and offset? I may just have to try myself and see
    Andrew
    Z32, 280mm front rotors, weight 1500kg.
    Mini cooper JCW runs 316mm rotors on the front, weight 1100kg
    If Z32 brakes are excessive for ae86, look at the Mini Cooper specs!! I know of a 560kg clubman sporting z32 front brakes...........
    It's just a context thing. Track (grip), bigger is likely better. Street, an ra60/mx62 setup works very well.
    Mazda calipers are great for the added sexiness......
    Research the disc widths too.
    Member filfilfil's Avatar
    Phil
    Just South
    Quote Originally Posted by af300e View Post
    +weights...inc rotors!
    Heres the drawing detail for the my RX7 caliper brackets (courtesy of Hen on toymods) ...you can measure the nissan hole spacing to compare...
    Oh yeah it uses these disks:
    "Disc- 280mm 180SX (from SR20 variety I think)"
    Might help
ID:	1320   Click image for larger version.
    Veteran slide86's Avatar
    Huw
    Hills
    you dont need an adaptor to bolt them up. i have s14 brakes on my car
    i use st141 struts and hubs and these calipers bolt straight on. the only thing i did was use a spacer between the caliper and strut to correct the offset for the disc. im also using the 280 x 30mm rotors.
  1. fav clubs/night spots
    By s13 james in forum Offtopic Discussions
    Last Post: 24th July 2011, 12:37 AM
  2. spots + cops
    By Dan_J in forum Melbourne & Vic Events and Discussion
    Last Post: 22nd March 2010, 07:42 PM
  3. where are common rust spots on E7??
    By Nic19 in forum General Topics (No Technical Questions)
    Last Post: 20th March 2009, 01:11 PM
