Results 1 to 10 of 11
Thread: gearbox oil
    Default gearbox oil
    hey guys/gals,
    was just wondering what oil people are using in there T50 gearbox ?
    brand etc....
    and how many litres go in?
    thanks
    Jonathan
    Cheap regular gearoil is fine, GL4 grade. Get the thinest GL4 on the shelf, like 75w80 or something like that. 75w-90 is what the manual says. Not over 90w or 120w as it may not shift. But if the syncros are old, you can use Dextron as a thinner gear oil. If you have new syncros, don't use synthetic or anything that costs too much, or the syncros can't wear in and you won't be able to shift. It will always feel cold.
    1.7 litres I think.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    chuck some ATF in BRAHH!
    FTP.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Yep 1.7 litres is what a T50 takes.
    Senior Member Vezza's Avatar
    Vesley
    Geelong
    What about good ol Castrol VMX 80? Or are people having better results with Dextron slush box fluid? Initial shift may be good, but any reports on reliability? Would been keen to know.
    Veteran slide86's Avatar
    Huw
    Hills
    all ls1, ls2 and ls3 T56 manuals use dextron 3 without any dramas
    Senior Member 45aken's Avatar
    Marko
    Redline shockproof aka smurf blood
    Vesley
    Geelong
    Quote Originally Posted by 45aken View Post
    Awesome stuff, but costs a bomb! lol. Used it in a mates R154, which was almost impossible to shift and totally transformed it.
    However have heard a few people say it can glaze the synchro's, because redline SP is a diff oil. When we pulled apart the box, the synchro's were very shiny... but that may have been like that previously. Hard to know really.
    Jeff
    Nsw/Sydney
    Is Penzoil Dextron III ATF recommended for T50???
    Tom
    SOR
    I use Redline MT (not shock proof) oil in my box T50 with TRD gearset works fine.
  1. Replies: 2
    Last Post: 3rd September 2009, 09:04 AM
  2. Gearbox T50 oil and exhaust Q
    By GEMTA22 in forum Technical - Questions
    Last Post: 27th July 2009, 09:22 AM
  3. what diff / gearbox oil do you use
    By pogi in forum Technical - Questions
    Last Post: 25th July 2009, 10:59 PM
  4. 4age engine oil / T50 gearbox oil
    Last Post: 27th May 2009, 11:27 PM
  5. Auto Gearbox oil in T50
    By v-tec in forum Technical - Questions
    Last Post: 8th April 2007, 06:31 PM
