Results 1 to 5 of 5
Thread: RWD water pump lines
    Senior Member AE86 Spoontah's Avatar
    Brendon
    Ellenbrook
    Default RWD water pump lines
    Hey guys, just a quick question as i am unsure about which lines go where.
    I have hooked up the two lines that go to the inlet manifold but don't know where the large line and small line from the back of the pump goes.
    Now i also have a FWD and RWD housing for the top hose of the radiator. Which one should i use as the FWD has the lines but the RWD one doesnt. Where do they go.
    Cheers Brendon
    i just plumbed my fwd 4age...found all the pics of which line goes where on google images- would give you links and all but my nets slow.
    Brendon
    Ellenbrook
    Okay, got it all sussed apart from the small line near the firewall which is part of the throttle body cooling. Where do i plumb that?
  • #4
    Veteran Nikkojoe's Avatar
    Tom
    The small line from throttle body that goes to the firewall goes to the back of head water outlet on a rwd (has a little pipe that sticks out that joins to the little pipe that you are talking about). If running a fwd back oh head water outlet, it will not have this pipe.
  • #5
    Brendon
    Ellenbrook
    Yeah i got a RWD one. Cheers Nikkojoe
  • Similar Threads
    1. WANTED : RWD Harmonic Balancer and RWD water pump pulley
      By fumeck in forum Cars or Parts Wanted
      Last Post: 11th March 2012, 07:42 AM
    2. WANTED: 4age Rwd Water Pump Pully And Rwd Alternator Bracket
      By BIGPORT71 in forum Cars or Parts Wanted
      Last Post: 26th May 2010, 10:11 AM
    3. WTB: RWD water pump and lines
      By AE86 Spoontah in forum Cars or Parts Wanted
      Last Post: 5th January 2009, 09:09 AM
    4. radiator and rwd water pump
      By ozsprintz in forum Cars or Parts Wanted
      Last Post: 8th January 2007, 12:57 PM
    5. Need water pump for RWD 4AG?
      By sLy1300 in forum Technical - Questions
      Last Post: 29th August 2005, 06:46 PM
