- any 4age main pulley
- either fwd or rwd pump but it has to have the matching pulley. You can fit a fwd pulley to what you have to make it work
- I am unsure if you can just swap the alternator pulley over, I dont see why not
i have a small port 4age in my 86 and its been running on 4ac pulleys/alternator since i got it.
what parts do i need to convert it? rwd pulleys/alternator/bracket & water pump or fwd?
what else would i need to know?
much help needed as i don't know sh!t!
i have my 4ac alternator setup on the same side as the extractors, what alternator bracket would i need to have a 4age alternator on the left side? doesn't look like there's much room for an alternator?
thanks,
if thats the case then you have the 4ac alternator and bracket, both have to go
any non ZE alternator and bracket will be fine providing your not using a rwd water pump rear half
thanks can you tell the difference between the rwd & fwd water pump, by looking at it?
if i do have a rwd water pump, i'm guessing i would need a rwd alternator bracket?
yes I can, post some pics
that is a 4ac front and back half. Which means you will have issues with the new alternator mount unless you get the JDM one. Anyway this in in my cooling guide:
go down to water pumps
ok thanks
