Results 1 to 10 of 17
Thread: AE86 Camber Tops Caster?
    Veteran bigm's Avatar
    Gold Coast
    Default AE86 Camber Tops Caster?
    Hey Guys,
    I read that ke70 strut tops in a ae86 give more caster,
    does that mean that ae86 camber tops in a ke70 gives me less caster?
    I am running cusco ae86 camber tops in my ke70
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    There are different variants of camber tops which give you different caster. I believe there are at least 2 different Cusco types for caster.
    Jonathan
    Stock AE86 camber tops come in 2 different offsets. The 4A-C spec cars have low caster tops, and the 4A-GE spec cars have more caster. The Cusco brand strut tops for AE86 also come in 2 different offsets. Most common, are the ones that give greater caster.
    SPIN the camber plate. so that the holes line up again but your adjustment can come back as well as in. so set it up with a diagonal line. then you have adjustable caster and camber. with some adj. lower control arms your set of ridiculous camber.
    Veteran blair's Avatar
    Blair
    Sheldon
    ^ wow never heard of that before... sketchy?
    Sameul
    Bulleen
    Quote Originally Posted by Frying Dragon View Post
    wtf i thought the holes only line up one way ??? brb im going to try this
    Sameul
    Bulleen
    nope you cant to it, the holes only go one way... do you mean the blue plate or the darker one underneath?
    Gold Coast
    you could redrill the holes if you were desperate, but i dont need to
    i now have so much caster my wheel hits the area where the battery mounts inside the engine bay hah
    Veteran slydar's Avatar
    Dimitri
    no chance nissan man.
    also the 2 versions of strut tops are not 4ac/4age.
    but power steering and non power steering type. the power steering ones have the higher caster.
    Gold Coast
    good to know
    does having more caster make steering heavier? so the power steering is used to assist the heavier steering? or that is just how it is
  1. WTB: ae86 camber tops/ camber plates
    By ae8620v in forum Cars or Parts Wanted
    Last Post: 12th August 2010, 09:29 PM
  2. AE86 Camber Tops
    By Monk in forum Car Parts For Sale
    Last Post: 26th August 2008, 06:51 PM
  3. ae86 camber tops
    By Trucka 115 in forum Cars or Parts Wanted
    Last Post: 4th July 2007, 10:11 PM
  4. ae86 camber tops
    By spoon in forum Cars or Parts Wanted
    Last Post: 27th December 2006, 09:20 AM
