Results 1 to 9 of 9
Thread: Microtech - issue
    Senior Member shuvke70's Avatar
    Jarryd
    Para Hills
    Default Microtech - issue
    I have a LT10 powering my 4agte ke70, the display randomly stopped working whilst trying to start it today on my hand controller.... also my fuel pump makes zero noise when i flick it over to accessories... quiet odd since its a noisey 044 pump. car still has power/ battery.
    can anyone shed any light?
    all help appreciated
    -Jarryd
    Mark
    the ecu isn't getting power maybe?? since the fuel pump won't come on without the single from the ecu, and neither will the display.
    is there any lights or anything on the actualy ecu that light up when powered? turn the ignition and see if the ecu lights up.
    after that check for any blown fuses. Then you will probably want to check the earth for the ecu and fuel pump.
    You really need a multimeter, to check various signals and voltages to see whats getting power and what isn't
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    is the light on the unit on? sounds like u just blew the fuse powering fuel pump/ ecu
    AE86 THE BEST
    Jarryd
    Para Hills
    no light on the unit at all. ill sus fuses when its day light. fingers crossed its just that! and YES a multi meter would be an excellent investment. thanks guys
    Mark
    there is one for like $17 but its worth paying an extra couple of dollars for the buzzer feature. sometimes its hard to hold what your testing, plus the probes and see the meter, so its good when you can set the thing to buzz when you get voltage!!
    Jarryd
    Para Hills
    was just a fuse. have a dicky cold start so its an absolute cunt to start in this weather when the water temp is reading 12 - 16. not fun at all.
    going down the road to get all the gremlins sorted out tomorrow.
    Eddie
    sa
    go see steve from jazmac hees a micro guru
    AE86 THE BEST
    Jarryd
    Para Hills
    brenton from fours n more sussed the wiring. he was disgusted in how bad it was. hole lot needed re doing... again!
    all sorted now. fours n more is only 2 blocks from me thank god..
    Veteran AJPS's Avatar
    Lonsdale
    Far out, not having much luck with that engine set up!
  1. Carby Issue :/
    By x744 in forum Technical - Questions
    Last Post: 18th June 2012, 11:19 PM
  2. suspension issue
    By khai2298 in forum Technical - Questions
    Last Post: 13th November 2009, 04:59 PM
  3. 22RE issue.
    By marvis in forum Technical - Questions
    Last Post: 23rd September 2009, 05:11 PM
  4. 4AGZE Issue
    By Narchi in forum Technical - Questions
    Last Post: 13th August 2008, 03:06 AM
