Results 1 to 10 of 17
Thread: 4K-C idle and running issue.
    Senior Member AE86 Spoontah's Avatar
    Brendon
    Ellenbrook
    Default 4K-C idle and running issue (now with vid)
    Hey guys, i'm having a bit of trouble getting my 4k to idle and run properly.
    It will idle nicely with the choke on but when you turn the choke off, the revs rise a fair bit, it will idle for 3 seconds and then it just dies in the ass. I can only get it to idle without the choke on if i crank it up to around 2000rpm.
    When i drove it with the choke on it was smooth in power delivery but when i turned the choke off the engine really struggles to rev like its being flooded.
    Any ideas as i think i've checked everything?
    Kieran
    Inlet Manifold gasket.
    about $10 and an hours work
    Veteran stx-16's Avatar
    Tweed Heads
    that happened to mine it was a thin wire with a green plug that came off the carbie (idle wire/fuse i think it was)
    the wire in side snapped try fixing that
    you play halo?
    add me GT: samnbhnc
    Brendon
    Ellenbrook
    I think it might be that as when i give the throttle a little "blip" you can hear a noise like it's sucking somewhere else
    Are you talking about the fuel shutoff solenoid?
    Tweed Heads
    ummm maby the work shop just said it was that wire
    you play halo?
    add me GT: samnbhnc
    Brendon
    Ellenbrook
    Started ripping off manifold to replace gasket and i'm taking all the emmisions shit off to prevent further vacuum leaks. Hope fully that will sort my problem out?
    Tweed Heads
    just dont fuck with the vacuum lines the actually do shit lol
    you play halo?
    add me GT: samnbhnc
    Senior Member Tally's Avatar
    Tally
    all you need to worry about is the dizzy vacuum advance line and the vacuum line that opens the secondary's.
    and charcoal canister
    Everything else you can rip off and block...
    ALWAYS LOOKING FOR KE25 COROLLA PARTS
    Brendon
    Ellenbrook
    That's all i was planning on keeping. I saw a 4k vacuum diagram from the bonnet somewhere that had bright green lines to show which ones to keep but i can't seem to find it!
    Tweed Heads
    it would be awsome if you could send it to me when you fine it
    you play halo?
    add me GT: samnbhnc
  1. Strange idle, running rich, please help
    By Sprinter Freak in forum Technical - Questions
    Last Post: 29th April 2012, 10:34 PM
  2. Idle and fuel problem, running rich
    By capatown in forum Technical - Questions
    Last Post: 6th December 2010, 10:36 PM
  3. 4AGE odd idle issue
    By JinxD in forum Technical - Questions
    Last Post: 18th August 2009, 07:21 PM
  4. 20V idle and rev issue
    By fat20v in forum Technical - Questions
    Last Post: 4th August 2009, 12:06 AM
  5. idle, running probs
    By ONI86 in forum Technical - Questions
    Last Post: 25th November 2006, 09:37 PM
