Results 1 to 4 of 4
Thread: kouki Trueno cornering light relay wiring.
    Senior Member Stain's Avatar
    Derek
    Far North
    Default kouki Trueno cornering light relay wiring.
    Ok. I've got a zenki Trueno body loom, but I've got kouki front indicators/parkers... so they have the cornering light function. (Clear corner light will activate on the side you indicate when the headlights are on)
    Now I've found a kouki Trueno cornering light relay, but the zenki loom doesn't have a plug for it so I need to splice it in.
    Does anyone have a wiring diagram or know which wires I need tap into and connect to which pins?
    Senior Member aaron's Avatar
    Aaron
    NOR
    83' 4AGTE Hachi - 335whp @ 22psi on United E85.
    Never ending build...
    Derek
    Far North
    Thanks, that's a good starting point. But I want to use the stock relay... so need to know which pins are which as well.
  • #4
    Some pics...
  • Similar Threads
    1. Blower Relay and Tail light Relay connections to 4age 20v ECU.
      By paulv in forum Technical - Questions
      Last Post: 9th January 2012, 01:33 AM
    2. WTB: Kouki Trueno Indicator/Side Light
      By KurtHS in forum Cars or Parts Wanted
      Last Post: 1st March 2011, 09:53 AM
    3. WTB: Trueno Tail Light Wiring Loom
      By pnda86 in forum Cars or Parts Wanted
      Last Post: 15th September 2010, 03:03 PM
    4. Replies: 18
      Last Post: 30th October 2007, 04:20 PM
    5. trueno headlight motor relay wiring
      By sanchez in forum Technical - Questions
      Last Post: 29th September 2006, 12:23 PM
