Results 1 to 10 of 49
Thread: Gilly's 86
    Ferny Grove
    Default Gilly's 86
    shell was found at the wreckers 4 months ago. had a lot of parts here for another shell i was piecing together, ended up sing the car you see here as it was already the one colour and fairly rust free, definately goo enough to base a build around
    specs are as follows
    BODY
    1984 ADM
    deleted rear pockets tech arts/slydar style
    modified front guards (thanks D)
    kouki headlights, parkers, fogs
    ADM zenki front bar + OEM Zenki lip
    ADM rear bar
    Kouki Whiteline tail light set
    ENGINE + DRIVELINE
    AE101 4AGZE
    Kaizen S/C oulet pipe
    180mm crank pulley
    2" intercooler piping
    unknown OEM intercooler
    modified AE101 loom + ECU
    T50
    JDM bellend and hard lines
    C's short shift
    EXEDY pink bits H/D clutch
    big single piece shaft
    T18 series one housing
    AJPS sway mounts
    TRD 2 way
    4.1 CW&P
    (my old diff, boomeranged back into my possession)
    FUEL
    ADM tank + modified pick up + high pressure in tank EFI pump
    under car surge tank
    bosch 070 pump
    8mm feed
    adjustable reg, not needed came with the motor
    SUSPENSION
    Front:
    shortened strut, GAZ coilover kit, ST185 AGX, GAZ 8kg/mm springs + GAZ helpers (cheers D for the welding)
    ADM brakes (for now)
    Braided front brake lines (ADR approved)
    p/s arms
    XT130 LCA's, new bushes and ball joints
    30mm RCA's
    Quaife quick rack
    T18 turnbuckle tierods, aftermarket turnbuckles here as well
    poly bushed sway links, mounts, castor rods
    Spats strut brace
    Rear:
    GAZ 36 way adjustable coilovers
    GAZ 6kg/m springs + GAZ helpers
    JDM OEM sway bar (1mm larger dia blink.gif )
    APEX rosejoint adjustable 4 link
    APEX rosejoint panhard rod
    APEX rosejoint sway bar links
    RIMS
    SSR Formula Mesh
    front: 14x8.5 -20
    Rear: 14x9 -15
    185/60 FD1's
    INTERIOR
    MOMO fixed back
    customised rail (cheers again D)
    Nardi classic on 100mm boss + 50mm hub spacer
    column spacers to suit lowered seat height
    Safety 21 6 point cage with b-pillar tags
    rear harness brace
    relocated battery to behind passenger seat
    timeless blue ADM trim
    Senior Member ThatsHowWeRoll's Avatar
    Dean
    Ballina
    such a sex machine.....the seat looks so amazingly good..
    John 1:12
    I agree,.......That thing looks nice!
  • #4
    Senior Member n00bvak's Avatar
    Novak
    SOR
    hahha, I like the foha lip taked onto the botom of you sprinter bar
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
  • #5
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    i love thoose ssr's
  • #6
    Veteran Jdm-Mcc's Avatar
    Jake
    Wagga Wagga
    Simplistic Sexuality......Your cars got it
  • #7
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    no matter how good an 86 looks cant get over this thing...
  • #8
    Senior Member Paul's Avatar
    Paul
    looks great gilly. Looking foward to seeing this thing on the road
  • #9
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    i love this car.. done well dave
    MY JZX83 (clicky)
  • #10
    i lobe this car long time
  • Page 1 of 5 1 2 3 4 5 LastLast
    1. WTB: Gilly Lip!
      By Beau in forum Cars or Parts Wanted
      Last Post: 12th September 2009, 06:53 PM
    2. Contacting gilly
      By SON57A in forum General Topics (No Technical Questions)
      Last Post: 14th February 2008, 01:06 AM
    3. gilly
      By Bobomacho in forum Offtopic Discussions
      Last Post: 17th August 2007, 11:38 AM
