Results 1 to 10 of 10
Thread: RA40 struts into a KE70
    Default RA40 struts into a KE70
    Have a good pair of these in my shed, new balljoints, rubbers, lowered springs shocks ect. worked really well in me last KE30.
    Now is there any reason why these cant work in a KE70.?? im getting mixed opinions
    Some say Bump steer is a big issue with these struts, then others say wack some 30mm RCA's on and bump steer be gone ...
    Also read the steering angle is different to the Pin angle or something, and it throws the whole Suspension Geometry out of whack?
    ANy advise would be handy, if they not worth putting in me 70 ill flog em off
    Cheers Guys
    <img src=http://img114.imageshack.us/img114/3193/p1020339jk4.jpg border=0 alt= />
    Anyone get the License plate of that B& Hammer?
    Site Supporter Javal's Avatar
    Josho
    Put them in. I am 95% sure they will fit.
    The only possible hurdle could be the diameter of the RA40 spring seat being too large for the strut tower. Then again, that could be just me being skeptical.
    If all else fails there's still ground to be made. If you've pulled a stock strut out, found out the RA40 one won't fit, then take a photo of the two side by side. Notice how there will be an absolutely negligible difference in length - no worse than converting to xT13x Struts - which has no repercussions. Go The RA40 gear, and benifit from having a strut that will take a 2" dia shock.
    c
    my mate is running ra65 struts in his 71 and it handles pretty well. It really low and there is n problem with spring perch fouling. He is running sigma arms but ra40 one should be sine as they are the same as xt130
    Well atm the spring on it is a KE30 item. Has had the lower Spring seat cut off and a KE30 one welded on. and has a KE30 top spring hat.
    So im assuming id have enough clearence, id just have to use the top part (with the 3 studs that hold strut to tower) from the KE70 struts and place them on the RA40.
    Also been reading, XT130 LCA's are the same as KE3x KE5x ones, which are also same as RA40, so in saying that ill end up with a little more -ve Camber yes?
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    they bolt in,
    KPI is up the shit but. i would do it if i had them sitting on the floor in the garage, its a good upgrade is your not planning on going any further than streeting it.
    the strut gives you actually a little bit of +ve camber?
    then when the lca come in and puts it out to about -1
    congradulations!
    you now need to get at least a 40mm rack spacer to achieve std lock
    FTP.
    Was planing on going AE86 with coilovers later down the track.. or some off the AJPS site ... Drool.... Just thought these would do till then.. All i ever do is drive on street, or a run through the hills out to me Aunts place.. Woo for me lol
    whats KPI?
    And what do you mean about the lock? will i loose the tight turning circle? im lost..
    Clinton
    Tweed Heads
    youll lose a fair bit of lock.
    KPI= king pin inclination
    there was a sweet thread comparing ae86 geom. and RAXX geom. on the old forums. ill try find it for you
    FTP.
    Yeah i seen that, expains the Bump steer and King pin angle.
    I might Flog these off and put that towards some 86 gear.
    They dont throw out the KPI or lock do they?
    edit this the page
    http://www.ae86drivingclub.com.au/bo...0&#entry610185
    Clinton
    Tweed Heads
    86 stuff does not.
    FTP.
    Ahh goodo,
    Ill just straight to that then, saves having to fart ass about later on.
    Thanks for the help Guys
  1. AE86/XT130/RA40 Struts
    By Vaughn in forum Technical - Questions
    Last Post: 3rd December 2012, 11:17 AM
  2. WTB (QLD). RA40 struts..
    By mc68 in forum Cars or Parts Wanted
    Last Post: 14th September 2012, 12:09 AM
  3. Wtb: Ra40/60 front struts
    By buster86 in forum Cars or Parts Wanted
    Last Post: 17th March 2011, 11:50 AM
  4. WTB [SA] RA40 front struts
    By cazman in forum Cars or Parts Wanted
    Last Post: 29th April 2008, 08:51 PM
  5. ra40 struts with brakes
    By gaz20v in forum Car Parts For Sale
    Last Post: 13th April 2008, 10:14 PM
